Just curious will 2 step colder plugs make you lose power na?
Just curious, I went on the dyno that I always go on and I was down from 423 to 401hp. and 403 to 385 on tq. NA..the only thing diff. was I put in colder plugs. from tr55's to the br7ef for the nitrous. I had a speedshop guy tell me that I could lose around 15hp from the colder plugs. Is there any truth to that?
LS1 Stock and AFR
Thread – 14mm
Reach - .708”
Socket – 5/8 hex
Seat - Taper
Stock Heat Range: 5
Gap: .060
Plug: NGK TR55 (stock number 3951); NGK TR55IX (stock number 7164); Autolite 764; Denso IT-16 (stock number 5325)
Nitrous (two steps colder)
Heat Range: 7
Gap: Consult
Plug: NGK BR7EF (stock number 3346); NGK TR7IX
hashtagBMW
Not according to the stickies.
LS1 Stock and AFR
Thread – 14mm
Reach - .708”
Socket – 5/8 hex
Seat - Taper
Stock Heat Range: 5
Gap: .060
Heat Range: 7
Gap: Consult
LS1 Stock and AFR
Thread – 14mm
Reach - .708”
Socket – 5/8 hex
Seat - Taper
Stock Heat Range: 5
Gap: .060
Heat Range: 7
Gap: Consult
Okay thanks for the help guys, maybe the car was down on power because it was pretty humid and hot out compared to when I ran on the dyno last time. Or I have something else going on I need to check. Thanks again.
Well my tuner tuned it on the bottle at the track a few months ago, I have the timing tricker coming on when the selenoids kick on. So it does pull timing when the selenoids kick on, I remember he said the timing tricker was pulling out 8-9 degrees of timing when I run, so he lowered it thru the tune to pull 6 degrees and the power came up on the bottle. Does it still pull timing when the system isn't armed ?
I swapped in BR7EF's before my Nitrous tune at Straightline Performance. He got my N/A tune dialed in and with jus a lid and cut-out I put down 343/361 (with 42 lbs/hr injectors for my 175 shot). Again, everything else was stock.
That's some pretty damn good numbers and doubt I will pick more with TR-55's.
1 Post
Sounds like you may have something going on with timing... why are you using the tricker and pulling timing in the tune? The purpose of the tricker is to allow you to not pull it in the tune... what he did does not make sense if you have it straight... you need some logs to see what the timing is doing when. That could explain your being down on power...
