trouble shooting....Granatelli window switch
Is there anyone running or have installed a Granatelli dual window switch? I just installed one on my 98 F-body and I'm having a little trouble getting it to work properly. Thanks!
I cant get the window switch to work. I have it wired up just as the directions said. I tested it a couple times in the garage and it worked. Get to the track 30 mins later and it wont spray. Ended up bypassing the window switch that nite just so I could spray the car. I'm not sure if its something with the settings on the switch or if I have a week tach signal.
I hope its something as simple as that...I checked over everything seems like a dozen times. I'm going replace all my connectors and make sure that its not that. Thanks
Im having the same problem with mine, i cant even get it to program, everything the instructions say will happen isnt, i hold the button down and the letters that pop up arent the same as what the instructions say will happen, i about ready to throw it out in the street, and mine didnt even come with a cap, i called granatelli and told them and they were supposed to ship the cap out over a week ago, also where are you getting your tach signal from OP? I think i may have a weak tach signal too.
car, dual, electric, granatelli, grandtelli, install, instructions, ls1, programming, rpm, shooting, switch, switches, trouble, window
