quick question...
Old Aug 19, 2010 | 08:08 AM
cheston11's Avatar
Default quick question...
ok so i just picked up a 200 shot (wet) from nitrousdirect... i am buying a bottle heater, rpm switch, fuel pressure safety switch and a purge kit...
i am looking at the fuel safety switch now and about to buy it along with the others but it has two kinds of switches, 4an and a 6an switch... which one should i go with for the ls1?
oh and any good suggestions on a brond or tyoe of rpm switch?
Old Aug 19, 2010 | 08:16 AM
ryarbrough's Avatar
Ditch the fuel pressure safety switch and just put a FP gauge in the car.... With those things it's not IF they go bad it's WHEN.... Like I've said before, I wish I had a nickel for every time I worked on a car that wouldn't spray and a faulty FPSS was the problem (I'd probably have like $2 ).
Both Nitrous Outlet and Harris Speedworks have great options when it comes to window switch/tps combos that also have a ton of other features. Give one of them a call and they'll be glad to help ya out!!!
Do you have any other things you'd like it to do? Progressive? Gear lock out? Etc?
Old Aug 19, 2010 | 08:27 AM
cheston11's Avatar
not right now, im new to the whole nitrous thing and advice is really helpfull but i am just trying to kinda open up to the nitrous idea safely and maybe build from there. i just read the sticky and am trying to purchase all the "safeties". once i get a good understanding of everything and all goes well i might move up a little bit but i still need to finish the intake on the car too before i go too much further with money. and as for calling them i cant but i will try to find a website for them. i am in iraq right now but should be heading home to my baby in october
Old Aug 19, 2010 | 09:00 AM
IWGF's Avatar
Don't sweat the FPSS, just get a FP gauge. FPSSs just make things more difficult because they always go bad.
Good luck on your deployment. I got back in April, still got all my fingers and toes.
Old Aug 19, 2010 | 09:26 AM
ryarbrough's Avatar
Nitrous Outlet - http://www.nitrousoutlet.com
HSW - http://harrisspeedworks.com
Hope that helps! Thanks for your service!
Old Aug 19, 2010 | 10:11 AM
Nitro Dave's Nitrous Outlet's Avatar
I use a fpss on everyone of my installs.The key is in adjusting it properly. Lots of people do not read the instructions or understand how to adjust it. The FPSS is a cheap piece of insurance. I have seen it save motors on several occasions because the customer was having fueling issues.
As for 4 an or 6 an, that depends on where your fueling is coming from. If you are pulling from the shrader valve it is a 4 an.
Old Aug 19, 2010 | 10:12 AM
cheston11's Avatar
http://www.nitrousoutlet.com/catalog...=26&section=86
good buy?
still gotta get the price though
Old Aug 19, 2010 | 05:10 PM
Chris@NitroDaves
Guest
Posts: n/a
The pricing is going to be set around $139 i beleive. Unfortunately we are out of stock on it.
