Pulling timing for N2O?
Old Sep 18, 2010 | 04:21 PM
gillbot's Avatar
Default Pulling timing for N2O?
I upgraded my old LS1 Edit to EFI Live so it's a bit easier to tune now. What is the preferred method for pulling timing? Put a resistor into the IAT to force a high temp and adjust those cells to pull ~2 per 50hp added in the Spark IAT table?
Old Sep 18, 2010 | 06:51 PM
jeepers_88's Avatar
Check out interface controller from harrisspeedworks.com. Thats what I use and it only pulls the timing when the kit is activated, so you can run full n/a timing off the bottle. Its really bad *** for the money.
Old Sep 18, 2010 | 06:54 PM
gillbot's Avatar
I need to pull more than 3 degrees.
LS1 3 Degrees
* The Interface uses the IAT Spark Advance Correction Table in the PCM for retarding timing. The Interface is limited to the values entered into this table, so if you would like to pull more timing then what is available for your application you can do so by modifying the IAT Spark Advance Correction Table.
Plus if I have tuning software, why not do it properly plus why buy something that I don't need.
Old Sep 18, 2010 | 07:07 PM
jeepers_88's Avatar
you can change that with your tuning software. my tuner made mine pull 7 degrees. You just have to mess with the IAT table I think. its in the instructions with the interface
Old Sep 18, 2010 | 07:09 PM
gillbot's Avatar
I can do that with a resistor, why buy that interface:
https://ls1tech.com/forums/nitrous-o...tor-trick.html
Old Sep 18, 2010 | 07:21 PM
jeepers_88's Avatar
personal preferance I suppose. The interface does other things too. And I like gadgets too
Old Sep 19, 2010 | 09:15 PM
Carter01's Avatar
I use EFI Live also and just pull it from the cells. Copy those tables on High low octane as well as in park/neutral if it has a manually controlled auto (mvb). Sometimes a auto swap will cause the car to loose signal and revert to tables you don't want to spray on, just a safety.
Old Sep 19, 2010 | 10:00 PM
Nitro Dave's Nitrous Outlet's Avatar
Dude,
You have everything you need with the EFI live. Use the custom operating system to pull the timing when the system activates. You dont need anything. you already have it. Just run a wire from the system relay to the pcm and it can swap bewteen the two tunes when the system activates.
Dave
Old Sep 19, 2010 | 10:45 PM
gregrob's Avatar
This ^^^
Old Sep 20, 2010 | 08:05 AM
Carter01's Avatar
Originally Posted by Nitro Dave's Nitrous Outlet
Dude,
Dave
Just trying to help since no one chimed in on EFI, LISTEN TO DAVE! He's teaching me!
Old Sep 20, 2010 | 11:35 AM
gillbot's Avatar
Dude,
Dave
I thought the custom OS portion was extra? Any more info on this? That would be awesome!
Old Sep 20, 2010 | 06:05 PM
john563's Avatar
Damn Gill got EFI live now congrats! I wanted this to pull timing like Dave said but did not have the extra coin..
I have the Harris sped works interface and I pull 4 deg with it(actually jeff did) with hp tuners so it works..:-) let me know how it goes with efi live I'm sure marky can help you with it
Old Sep 20, 2010 | 06:10 PM
gillbot's Avatar
Yeah, I finally moved out of the stone ages. LS1 Edit does work, but having to pay them for every update just got old so I bought a different suite.
Old Sep 20, 2010 | 06:17 PM
joeys99z28ss's Avatar
good way to go
Old Sep 20, 2010 | 06:33 PM
john563's Avatar
so what size shot you gonna run? I have 100 right now..might step up to a 125 not sure yet though cuz of the 4400 stall but sam is sprayin a 150 on his pt4400..
Bent a rim and as soon as I get my wheel back on gonna play with it and see if I wanna step it up or not but for now 540rwhp feels pretty good :-)
Did not realize you had to pay each time with ls1 edit..So yeah I dont blame ya..I think you'll be much happier now..
Old Sep 20, 2010 | 06:35 PM
gillbot's Avatar
I've used all of them, including tunercats. EFI Live has always been my preferred but HP Tuners seemed easier to get in the used/cheap market. I just got lucky on this one and it worked out for me.
Old Sep 22, 2010 | 04:17 PM
gillbot's Avatar
No other input on this?
Old Sep 25, 2010 | 06:10 PM
gillbot's Avatar
ok, aside from the custom OS, how does every one else do it?
Old Sep 25, 2010 | 06:15 PM
BLK02WS6's Avatar
Custom OS is absolutely the way to go for a street car or car you race on motor as well as nitrous... why you still asking - get'er done!
Old Sep 25, 2010 | 09:13 PM
c6 batmobile's Avatar
Dude,
Dave
Where do you run it off of the relay and what wire in the PCM would you tap into? Will it work with a wet shot as well?
