Just Bought My Wet Kit.
So i just bought a wet kit from Harris and was wondering about the placement of the nozzle, i didnt get a plate and was wondering where the nozzle goes, do i need a smooth bellow? will the nozzle work in the factory accordion style tube, also where can i get a cheap window switch?
I use to run a HSW nozzle in my stock bellow. It didnt take long for it to fall out. I got lucky, it fell out while changing jets. Had I made a run, there could have been some real problems. I bought a smooth bellow for it and it worked well. I made the switch to the HSW 92mm plate kit and I'm very happy with it for now.
Hold your hand at the end of your vacuum hose. Install a 2 ft extension and feel the end again still the same vacuum.
Your intake tube is the 2 ft extension. Hence the reason for a smooth bellow, and a cai to make sure there is no resistance to that vacuum pulling air through.
Nitrous Outlet has one too. N.O. window switch
I run the MSD. It works good. Know several guys that run the N.O. switch. It seems to work well also.
