Proper Way To Purge W/O Purge Kit
Yea im going to buy one this spring along with a fuel pump and bottle heater but for the mean time what is the process of purging it through the motor
The brand X purge kit is only 65.99. No since it taking a chance in having a nitrous backfire from purging into the motor.
http://www.nitrousoutlet.com/catalog...2&product=2890
Either that or loosen the B-nut at the solenoid and bleed the air out.
Dave
Dave
Put a manual button and thumb it into the motor. When you hear a car sitting there getting ready to stage they hold the rpms just off idle then bam real fast rev, they are thumbing it or tapping the activation button. A purge gets the air out to the solenoid, but thumbing it gets it out through the solenoid. I do both.
This is kinda the answer i was looking for, im going to get a purge kit this spring i just dont feel like spending any more money on my car until then, i would like to play with the nitrous a bit though before i park my car for the winter, so thats why i was asking this question.
burn out or just hit it once before you race,it will surge but it will clear out and youll be ready to go.ive never had a purge either and ive had n20 for 5 years,so you should be ok.
If you aren't bracket racing or racing for money, no real need to risk blowing up your motor with a questionable purge. Purging is more for consistency then anything else.
I will have a purge kit this year before I take the truck out but never had one before. You occasionally will notice a moment of hesitation when you first hit the nitrous but it will have a virtually immeasurable effect on your time.
Obviously guys run a short burst just before the run but if you don't need that extra 10th why risk it? That is how I look at it.
