Harris Speed Works Microedge?????
Old Jan 19, 2011 | 04:44 PM
Trev_SS's Avatar
Default Harris Speed Works Microedge?????
I will be purchasing a Wet plate kit from HSW and I want to get the Microedge. I guess I haven't done my research well enough or I just don't understand. Does the Microedge act as a timing tuner. Guys help me out I am about to purchase this from them and I just need to fully understand what exactly this does and its features. Thanks
Old Jan 19, 2011 | 05:50 PM
subhumanzz's Avatar
the microedge doesn't pull any timing. the unit they have that pulls timing is called the interface.
Old Jan 19, 2011 | 07:11 PM
Trev_SS's Avatar
OK so the micro edge just acts as a WOT switch and controls other safety items also.
Old Jan 20, 2011 | 08:45 AM
Nick@HSW's Avatar
Exactly, if you want timing or fueling that is the interface. The microedge is tps, rpm window, a/f shutdown, time delays and gear lockout. You can also upgrade the microedge now or down the road to a progressive controller. If you have any questions don't hesitate to ask. Thanks.
Nick
Old Jan 20, 2011 | 01:26 PM
Trev_SS's Avatar
Nick what is the differences in the progressive and the regular microedge? Thanks
Old Jan 20, 2011 | 01:54 PM
SuperSlow02's Avatar
Progressive will let you bring the shot in slowly. Like ramping it in from 25-150 over the corse for a few seconds. Greatly help if traction is an issue
Old Jan 21, 2011 | 10:15 AM
Nick@HSW's Avatar
Thanks superslow. The progressive simply pulses the solenoids to break up the hit. Our unit can pulse based on rpm or time in a non linear curve. This can be programmed gear by gear as well.
Nick
Old Jan 23, 2011 | 07:44 PM
LilJayV10's Avatar
Nick
When you say gear by gear do you mean like a 50 shot in 2nd, then 100 in 3rd and so on or am I reading it wrong?
