Front fuel cells for nitrous?
www.nd.edu/~caschenb/dpnitrous
there's a couple pics of my setup i built for my car, you dont have to move your battery. i got it from triangle.
Triangle Engineering is where you get the aluminum tank, as mentioned above. Here's some pics and more info for you.
http://www.derty.org/?body=Installs&content=directport
Originally Posted by tuff
Fast blackta i like your setup do you have a part number.
sorry i have no part number, but i ordered it from jerry bickel racecars (if you do a yahoo search i think they have a website)
If I order everything on that price list at that site, will I have everything I need to use for my 150 wet shot, as far as a stand alone fuel cell?
And what is that on the drivers side that looks like another small fuel cell?
Thanks.
I looked on Triangle's site, the smallest fuel cell I saw was 3 gallons and its 15 inches tall.
no, on the opposite side...didn't move the battery.
have to move the fuse blocks and mount as shown in the pics (or however you can do it)
have to trim a little metal to let the tank sit all the way down like i have it...i just mounted the pump right under the tank.
i think that's the correct tank.
any more questions, just lemme know
Triangle makes a 1 gallon cell, they just don't list it. If you want it a custom size they will do that too. Each cell is made to order for the most part. My parts list will get you pretty close to what my system is like. You can probably sacrifice some parts for others, but at least you should get the general idea.
6 3/8 x 6 1/4 x 12 1/4", is that the same one you have?
What pump are you using?
Man, they've upped their prices a bit. But yes, I have the one gallon cell cut down 4". If you get it have the mounting tabs moved to the top. It will fit into the battery area perfectly with no cutting. To mount it to the front frame support I justed used a threaded pop rivet into the frame. I'm using a Holley black, which will be a good amount of pump for what you are looking to do.
Here's a set-up that may be interesting - 2nd picture
https://ls1tech.com/forums/drag-racing-tech/141273-new-custom-products-billingsley-racing.html
Couldn't you just use the fuel cell for your stand alone?
David
David
8 SEC SLOPPY SHOT!!!
Originally Posted by Quickin
Man, Triangle said the 1 gallon cell is $170.00.
Summit has that same tank for 70.00 you still will be cutting it down though
Do I have to pay a metal shop to do it for me?
I also used a Triangle 1-gallon and had it cut down:
www.cofba.org/users/reckless/dp_fuel.html
Billingsley Racing sells Triangle - sponsor >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
