money maker kit
Old Feb 24, 2011 | 09:41 PM
midnight rider's Avatar
Default money maker kit
just wondering. ive seen alot of you talk about the money maker kit, how much is this set up and will it work on a stock ls1? also just wondering. how close will a bone stock ls1 automatic camaro be to runnin with a lt1 camaro w/ dart out the box heads, hot cam, 4.10 gears, stall conveter, cai, msd ignition, and 10.5:1 compression.oh and drag radials. and what hidden kits are out there for for the lt1s?
Old Feb 24, 2011 | 09:43 PM
xX-Z28-Xx's Avatar
What all is in this setup?
Old Feb 24, 2011 | 09:45 PM
its in a 94 z28 camaro. fully adjustable rear suspension
Old Feb 24, 2011 | 09:47 PM
xX-Z28-Xx's Avatar
Does the kit include the suspension?
Old Feb 24, 2011 | 09:48 PM
lemons12's Avatar
You need to contact the sponsor. People don't discuss this kit for a reason.
I haven't checked prices in a while so I won't quote that, it will work with a stock ls1. I recommend plugs a fuel pump and pulp some timing however.
*phone
And asking what will win against what is for Dyno racing forum, not nitrous oxide.
Old Feb 24, 2011 | 09:55 PM
how do i get a hold of a sponsor. what fuel pump would i need? and wont taking the timing out affect the car when running on motor.
Old Feb 24, 2011 | 09:59 PM
lemons12's Avatar
All the sponsors are to the right of the page.>>>
A walbro 255 will do you fine or a racetronix if you have the cash.
It will only pull timing when nitrous is activated.
I wouldn't run a kit without a window switch but some would argue it.
Old Feb 24, 2011 | 10:01 PM
nitrous outlet is the ones i need to talk to right
dnkynrbk's Avatar
Nitrous outlet makes the kit. Contact Chris
Old Feb 25, 2011 | 08:58 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
PM me for more info!!
Old Feb 25, 2011 | 03:47 PM
Chris@NitroDaves
Guest
Posts: n/a
The setup will work with a stock LS1 without a problem. We really dont share to mcuh info about the setup due to it's nature unless it is purchased. The system can be jetted newhere from 50-300hp with the option for more if needed.
There isn't much i can say about it but if you would like to contact the original creators of the system then give me a shout.
Old Feb 25, 2011 | 06:48 PM
Nitro Dave's Nitrous Outlet's Avatar
This is pretty messed up and un professional. Its so secrete the money maker is our baby and creation. Lots of people have invested there hard earned savings in order to have a hidden set up not everyone knew how to find.
Are you really willing to screw over all these people just to add to the messed up things you have done to us out of spite?
You should really rethink your thought process here...
DAVE
Old Feb 25, 2011 | 07:05 PM
lemons12's Avatar
I buy nitrous outlet for a reason.
Old Feb 25, 2011 | 07:15 PM
TwoFast4Lv's Avatar
When I bought this setup many years ago NX has no idea's or help for me.
Nitro Dave here dailed me in tight and the kit paid for it self in short order.
How does it work? Majic! ;D
Old Feb 25, 2011 | 08:54 PM
krissoto's Avatar
I personally do not think that even with a money maker kit and supporting fuel pump that you will wax this LT car. If its an H/C car with full susp and other supporting mods, a nitrous kit alone will not be enough to help you. Unless you are not mentioning tires and so forth, I think it would be very difficult to do....Bone Stock...GL trying tho...
Old Feb 26, 2011 | 10:44 AM
dnkynrbk's Avatar
So very TRUE.
Old Feb 26, 2011 | 04:30 PM
fatboyzcamaro's Avatar
how much is this kit
Old Feb 26, 2011 | 11:18 PM
dnkynrbk's Avatar
You need to call NitrousOutlet directly. Call Chris on monday he will be glad to assist you.
Old Feb 27, 2011 | 06:32 AM
Firehawk441's Avatar
Unprofessional...
Old Feb 27, 2011 | 03:03 PM
99 Blue Bird's Avatar
question for N2O Outlet. can the money maker b installed on other intakes like the BBK? or do they have to be stock gm intakes?
thought it would be easier to ask here than to call and waste yours guys time with such a small question.
