where is the best place to buy nitrous button?
You can google it but it is real easy. You have to take the switch out the steering wheel and re-solder a couple of things on the circuit board and find the wires going thru the air bag coil. Make sure you send the negative side thru the wiring the the switch and air bag coil because the wires are pretty small.
just make sure you dont hit it too soon jr... gots to time that **** right like them boys in tha fazt and the furiouz.
oh and even though you have a button make sure to install some safety things as well, like a wot switch and a window switch. We dont need someone blowing up there car because they hold a button at the wrong times and blow up there motor then blaming nitrous
Here:
http://www.lastofthebreed.com/Servic...bodyStereo.htm
http://www.camaroz28.com/forums/showthread.php?t=737357
You will have to do a little thinking and looking at the wiring in your car. Make sure you have a voltmeter so you can ohm out the wires you need. If you are only shooting one stage then you only need one wire to provide a ground path to the relay for the nitrous.
