My HSW Brute Force 78mm Plate Kit Install w/Pics!!!!
Alright guys just wanted to show some pics of the install everything is done all the wires are ran. I also purchased a microedge and ashtray switch panel from them. I have some pics of everything installed. Let me know what you think. Thanks Trevor
Also showing off my hardwire passport x50 install!!!
Thanks for looking.
Thanks for looking.
Nice work man! Looks just like my install, only I have the -4 feed. Get a purge hose hooked up to that solenoid and go spray the **** out of that thing. Its begging you
P.S. try your purge first, before you spray. When I did mine I had a metal shard get stuck in the purge solenoid and hang it open until I got the bottle shut off. When I took it apart I found the piece of metal sitting on the plunger seat. I thank god I didnt go right to spraying it and have it hang the actual nitrous solenoid open on me. It was probably left over from manufacturing. Shows that its just good practice to purge all the lines out to atmosphere before giving them their first use.
Thanks man. Yea I have the purge line already ran I just took it off while i was running all th wires. I will definally purge it first. I need to get the bottle filled I am just waiting for the nano to come in so I can put the valve on the bottle.
Thanks man yes they do make some good products I am very pleased so far.
I love the passport so far and like how's hardwired too.
Yes they are the ls1/ls6 brackets that harris speedworks offers with there brute speed package. Excellent quality if you ask me.
Thanks, I am hoping to get it dyno tuned in the next week on a 150 shot. I will post up numbers when its done.
Thanks I just got the NANO in today and will post some pics of the bottle with NANO in this thread.
Did you order customs lines from your solenoids to the plate? My lines are waaay longer and don't look very good.
I know running a shorter line can effect the way the bottle hits but if you look at Nitrous Outlet's kit they have those short lines from the solenoids to the plate. That thing has to hit harder than two feet of line on the HSW kit.
