Zex wont "learn" tps.. Help!!
http://www.youtube.com/watch?v=jMAX4BW_aRk
As for the Zix kit .. My buddy down the street from me has been fighting with the same kit you have for a couple months he doesn't have a lot of time to mess with it..
Good luck with the kit..
I've been using the TNT 90mm Power ring kit for the last year with Nitrous Outlet noids.
I just switched over to the Nitrous Outlet 90mm Plate this week. I will be testing it out next week.
I cant say Zex is **** yet because I have no idea if the failure is MY fault.. BTW thanks rmata.. I only have one idea left and that is to run a meter on the tps and see if the wire I am tapped into is putting out the right voltage range for the NMU to read.. I have read somewhere that it needs to put out at least 4.5V at WOT for the system to do its thing..
I have run a zex kit for years and dare I say, it's as good as anything out there if you stay with a small shot.
Once you get your tps hooked up to the right wire you should be good.
It has been a long time, but if I remember, you want the wire off of pin #22.
If hooked up properly, go by the directions from zex, it is cake.
My zex kit worked like a charm. Lol at the haters. I guess pacesetter is Latin for junk, since we have kooks 17/8?
I checked the voltage and sure enough I had the wrong wire.. problem solved
