Puddle the intake??
Old Dec 28, 2001 | 11:31 PM
BIGBOS's Avatar
Default Puddle the intake??
Would this ever happen with a wetshot from TNT or another brand, on an LS1?
Old Dec 28, 2001 | 11:50 PM
Slow Z28's Avatar
Default Re: Puddle the intake??
i'm sure when you get up higher in the jetting it could possibly happen, but with the 100 shot i've never had a problem. My kit is the TNT
Chris
Old Dec 28, 2001 | 11:57 PM
BIGBOS's Avatar
how high in the jettings? 150?
Old Dec 29, 2001 | 01:03 AM
bigSS's Avatar
I didn't know that puddling would be directly affected by the shot size. I suppose it makes sense. I do know that at what RPM you spray WILL affect it. Make sure to have that window switch set at 3K (I think), otherwise you will have a problem!
Old Dec 29, 2001 | 07:27 AM
Slowhawk's Avatar
LS1Tech Sponsor
Puddling is mostly found when there is not enough velocity in the intake.Like too low of an RPM or the noid sticking between shifts.
You can run a 500hp shot if you have enough RPM to carry the fuel in the air.
Old Dec 29, 2001 | 11:14 AM
Slow Z28's Avatar
yeah, the rpm is mostly related to the problem like the above people said. the 3000 is the lowest i'd spray at. plus with our motors, i don't think kwe have enough rpm to carry a 500 shot though. <img src="gr_stretch.gif" border="0"> would be cool as hell. i think the most i'd run through the intake as a wet shot would be 200hp. but that's just me. many have done that setting, and it works. any larger and it will become a problem, again in my opinion.
Chris
Old Dec 29, 2001 | 11:45 AM
BIGBOS's Avatar
Looks like I will get a window switch when I finally decide to do it...do full throttle switches work with the wetkits?? Or does the TNT kit come with something like that?
Old Dec 29, 2001 | 11:55 AM
Slow Z28's Avatar
i'd get both, and i think the WOT switch comes with the TNT kit. i have mine set for 3000 on and 6200 off with a 6300 shift point. i did not want to spray through the shifts on my A4 trans. anyways, normal shots like 75, 100, or 150 shouldn't have any trouble with puddling if you use the window switch. good luck.
Chris
Old Dec 30, 2001 | 12:48 AM
BIGBOS's Avatar
Thanks...and thanks for the help... <img src="gr_stretch.gif" border="0">
Old Dec 30, 2001 | 07:08 PM
Chris Spiess's Avatar
[quote]Originally posted by z28kid98:
<strong>i think the most i'd run through the intake as a wet shot would be 200hp.</strong><hr></blockquote>
I agree with Chris, I'd be leary of going beyond a 200 wet shot w/o going to a direct port setup. The manifolds in these cars - obviously - were never designed to carry a 'wet' charge, so fuel drop out is certainly a posibility, no matter the intake velocity.
