90mm 2 stage plate... dyno #'s
What kind of RWHP gains should one expect from a Nitro Dave's 2 stage 90mm plate setup. It has NX solenoids, 15lb bottle, and its on a 402LS2 with a TH350 and 9" behind it. I'm also running a standalone fuel system with 9-10psi, bottle pressure was 950-1000.
On a 200 shot the car gained 176rwhp, but on a 100 shot it only gained 56rwhp.
AFR was 11.5-11.8 throughout the dyno pull.
Thoughts? Comments?
Thoughts? Comments?
Bottle pressure was 950-1000. AR472 plugs at .029"
484rwhp/441rwtq - NA (29° timing)
660rwhp/556rwtq - 1st stage 200hp (19° timing)
715rwhp/576rwtq - 2nd stage 100hp (18° timing, 710rwhp @ 16°)
402ci LS2 with 330cfm CNC'd 317 heads, FAST 90/90, 248/254cam, 11.2:1, 93 octane in tank and 110 leaded in standalone fuel cell pushing 9psi.
built TH350 with 8" spragless Transmission Specialties converter... 4800na and 5700n2o flashes on dyno pulls.
I think thats about it!
I guess I need to make some passes and read the plugs... Car felt and sounded great on the dyno.
I asked him to use a different spark plug, Do a flow consuption test to make sure the system is flowing the nitrous amount it should be, and once all that is done if everything checks out we will evaluateif its just puching through the convertor.
Dave
Basically what Dave said. I honestly don't think there's much wrong with it, but we'll see after I check some things and make some passes. I really could care less about dyno #s if it ETs and MPHs like it should.
I definitely will.
*I was looking at my dyno pull logs on my laptop and noticed that my voltage was dropping pretty low on my last few pulls... that might explain the lower #'s on the 300 shot as well.
I definitely will.
Links to an upcoming feature of the car in FSC.
http://www.nmcadigital.com/2012/01/1...re-sneak-peek/
http://www.nmcadigital.com/2012/03/1...s-fast-f-body/
Video of it at the track: (1st pass is 200 shot, 2nd one is NA)
http://www.youtube.com/watch?v=l3qc0I8EBFE
