My Stock shortblock/cubic inch cam-only entry:) 56k beware
#123
We have run VP110, and are now running VP C14.
Base timing at 28*, pulling 10* as soon as the nitrous turns on. We are 82/42 now with 9psi on the nitrous side. NGK 10's.. And next time out, we are going to put some timing back in the engine I still think it wants more.
#124
#127
We haven't had a lot of heat either, we started with 9's. What I like about the 10's is they seem to make all the plugs much more consistent. And we probably could stick with VP110, but I'm a dealer for VP and this C14 stuff is pretty killer for a standard leaded fuel.
#128
Martin, I have been racking my brain with the wiring setups, with regular 5 pin relays, it simply cant be done to run all three systems together. Might not have been a "good" outting for you, but at least you didnt break anything (not really), and you did manage to shave .01 off your time.. I'd call that a good track outing any day.
Pin 87 (normally closed) on my nitrous relay currently goes to my solenoids.
Thanks for the kind words, it was hot as hell and I guess I did manage a 1.30 60' on a 275 radial in 92* and 130* track temps.
#129
16 total on 93 with those jets doesn't sound far off but monitor the plugs all the same whenever possible. I will be adding 2* back into mine and then read the plugs to see where and how far it moves the heat down the strap. That will put me at a total of 19*.
#130
No problem, and I run what Whitey said, Sunoco 110. It leaves a yellow hue/fuel ring when burned. I can see a faint yellow line at the bottom of the porcelain, nothing tremendous, but I can see it against the stark white of the rest of the plug.
#131
Next smallest jet I have that I could use is a 38 so I was going to put a 78 in the nitrous side with the 38f or I have a 36 and a 35 also. I really want to leave the 46f in and get a 88n or 93n jet locally along with a 40 to use with the 82n and a 99n for my 50f jet I have.
That's why I asked ATV in that guess how many nitrous pills in the jar thread when he made the comment he could fill one up too for some jets on the low. 5 bucks a jet sucks!
#134
When I asked you about a month ago what fuel jet you ran with the 82n jet that's what I was basing my tune-up off of. That's why I had 12* pulled to be extra low on timing because I knew it would be lean but lean like we like it. Bottle pressure gauge issue then became apparent, and then after my last outing this weekend I realize that it's a 46 jet this whole time! I need glasses
#135
F body, im at the track right now and i cant get the car to 60' better than a 1.55 im getting really frustrated. I tried loosening the front all the way and it doesnt seem to help. The is a pretty big hesitation off the line before the nitrous kicks in. I cant figure it out! Theres no air in the line and my bottle pressure is at 950 psi. Any ideas man??
#136
#137
When he does that or if you're racing by yourself purge your nitrous 2 or 3 quick times before you pull in to light the second staging light.
This is what I do when I remember
If the car isn't spinning and it's just hesitating there is air in the line or you don't have the window switch set-up right.
Do you have the tach output settings/how many cylinders you have on the window switch set at 004 or 1? What window switch are you using?
