My Stock shortblock/cubic inch cam-only entry:) 56k beware
Old 06-26-2012 | 11:45 PM
  #141
n2ols1cam's Avatar
Originally Posted by camscam02
Set your window switch at 3000 and bring the rpms to 1500-1800 and stop the pedal to the floor
Originally Posted by Fbodyjunkie06
This, and when you pull up to the line, light the first light, wait for the other guy in the other lane (if you're running someone else) to pull in and at least light his first light.
When he does that or if you're racing by yourself purge your nitrous 2 or 3 quick times before you pull in to light the second staging light.
This is what I do when I remember
If the car isn't spinning and it's just hesitating there is air in the line or you don't have the window switch set-up right.
Do you have the tach output settings/how many cylinders you have on the window switch set at 004 or 1? What window switch are you using?
Im sorry for the late response, i got booted off the track for going too fast without a cage. Guys i dont have a window switch. My nitrous is activated by a full throttle switch. i take the line off the plate and purge out the air before my runs because i dont have a purge. could that be the problem? also my nitrous line from the noid to the plate is about twice as long as my fuel line from the noid to the plate. Could that be a problem as well?
Old 06-27-2012 | 09:32 AM
  #142
86cutlass350's Avatar
Originally Posted by n2ols1cam
Im sorry for the late response, i got booted off the track for going too fast. Guys i dont have a window switch. My nitrous is activated by a full throttle switch. I also do have a purge. i take the line off the plate and purge out the air before my runs. could that be the problem? also my nitrous line from the noid to the plate is about twice as long as my fuel line from the noid to the plate. Could that be a problem as well?
purg it threw the motor?
Old 06-27-2012 | 10:42 AM
  #143
n2ols1cam's Avatar
i took off the line and purged it.
Old 06-27-2012 | 01:28 PM
  #144
camscam02's Avatar
**** I have from 32-38 covered I guess the guy I bought my kit from ran a lot of 150 and 200 tune-ups. I need some camscam and carter01 jets
I need 40-50 really.
Thats only 50 bucks and the piece of mind of not worrying about jets. Seems like a no brainer to me! Bite the bullet and do it. You sport the Nitro Dave colors... help him out Dave!
Old 06-27-2012 | 03:13 PM
  #145
Fbodyjunkie06's Avatar
Originally Posted by WhiteLTone
yessir, or girlfriend - whichever, you know what i mean.
LOL I thought that's what it was.
He does make very nice products, I don't know if it will work with my set-up though as I use TPS voltage to activate the kit and not a wot switch like he has in his instructions. Wot switch would use 12v and TPS uses 0-5v.
I will ask him.
Old 06-27-2012 | 03:19 PM
  #146
You need a window switch and a purge.
Not having the purge is what your problem is.
http://www.dynotunenitrous.com/store...?idproduct=288
http://www.dynotunenitrous.com/store...p?idproduct=24
http://nitrousoutlet.com/catalog/pro...2&product=2890
Old 06-27-2012 | 03:39 PM
  #147
n2ols1cam's Avatar
Ok i will get one asap. but if i pulled it off the plate and purged it before i made the run wouldnt it be ok? or no?
Old 06-27-2012 | 11:15 PM
  #148
I'm not an expert on gases and how they change states and when and where but I would think it's not doing the same thing.
Old 06-28-2012 | 09:45 AM
  #149
n2ols1cam's Avatar
i appreciate your input, thanks man.
Old 06-28-2012 | 10:20 AM
  #150
10secZ28's Avatar
my opinion, if your pulling the line off the plate before the run and you do your burnout yada yada yada by the time you stage chances are you will still have the initial air in the line when you floor it. I always purge right after i light the first bulb to ensure all air is out. just my 2 cents
Old 06-28-2012 | 10:37 AM
  #151
n2ols1cam's Avatar
ok. i will get the purge on and go from there, thanks for the advice.
Old 06-28-2012 | 11:58 AM
  #152
WhiteLTone's Avatar
Mines not on window switch right now either. I cant get the N2o outlet progressive to pick up rpm on the right tach settings. We jus bumped my rev limit up to like 8thewsand rpm
anyone know what tach signal the msd 6010 uses for rpm? 000,004,002 im lost.
Old 06-28-2012 | 07:47 PM
  #153
suicidal racing's Avatar
what is everyone sitting at for quench wise?
Old 06-29-2012 | 12:51 AM
  #154
Should be 004.
The N20 progressive uses the same one 004 unless you have a distributor and don't have coil on plug.
Old 06-29-2012 | 12:52 AM
  #155
This is a stock bottom end mota we don't care about no quench round here! LOL
**** if I know lmao.
I'm just a dumb redneck with a heavy right foot, a bag of nitrous jets and a, "if you ain't first you're last" attitude.
Old 06-29-2012 | 05:52 AM
  #156
WhiteLTone's Avatar
Whats quench? I got new tires yesterday, puttin her threw some more p90x workouts.
Old 06-29-2012 | 06:09 AM
  #157
psh i thought i was the dumb redneck around here..lol
i think im like 39 with my .045 gaskets..ive been thinking about gaining some quench by going to gm 51s or bigger ill lose some comp not much though 11.93-1 to like 11.76-1 i think..it would give me a better tuning window though
figured i would ask an see what everyone was at first before i make my final choice..i got the 45 cometics already..but that was when plans where diff,even with 51s it would only be 45 quench which is still low for a big juice deal..
Old 06-29-2012 | 08:28 AM
  #158
ATVracr's Avatar
More N20 the bigger quench you'll want...will help it not be so timing sensitive.
.060-.070 ..... some of the big boys are around .100
When they soften the chambers they are just angle cutting/milling the quench pad.
Old 06-29-2012 | 11:33 AM
  #159
Don't you have a car to build mister? Mmmhmm that's what I thought!
I can't wait to see ya'lls car run. Did maxipad make it to Reynolds do you know?
Old 06-29-2012 | 12:54 PM
  #160
ATVracr's Avatar
Too hot !
No show from what I heard.
Quick Reply: My Stock shortblock/cubic inch cam-only entry:) 56k beware
