I want nos
Old Mar 31, 2004 | 04:45 AM
Zerokube's Avatar
Default I want nos
What would be the best set-up for an almost stock ls1? I dont anything big just somemore power. Anyone?
Old Mar 31, 2004 | 06:58 AM
Fast SS on TNT's Avatar
Good beginner kit would be an NOS #5177. Easy to install and with the 125 jets give you about 80hp to the rearwheels. It's relatively safe, as long as you keep the bottle pressure regulated to 1000psi or less, and use a window switch to protect from over revving (if you have an M6). This was my first nitrous kit, and it was fun for about a year or so.
Personally, I prefer a good wetkit. Like Texas Nitrous Technology or Nitrous Express. The kits use a combination of fuel and nitrous sprayed through foggers that feed into your throttlebody. They are just a little more work to install, and are a bit more expensive. However they do rate thier horsepower at the rear wheels, and believe me, when you hit the juice with a 150 shot, there will be no mistaking that you are running a wet kit.
Be sure to get a set of NGK TR6 spark plugs. And get an MSD/NOS/Mallory window switch to protect the motor. Follow the directions, never spray below 3200rpm, seek medical assistance, some assembly required, batteries not included. Nitrous will void your warranty.
Old Mar 31, 2004 | 09:42 AM
z98's Avatar
z98
You need two bottles. The big ones.
Old Mar 31, 2004 | 10:05 AM
1BadAzzWS6's Avatar
the 5177 kit is a good dry kit and is easy to install. Just make sure you don't use any type of advanced programming like the HPP3 or the air temp module. Also make sure you use copper plugs, NGK TR-6's.
Old Mar 31, 2004 | 10:15 AM
F-Body Garage's Avatar
I did the TNT F1 wet kit. Right now I'm spraying 100 shot and loving life. It takes a little time to get it all hooked up, but once you done its well worth it!
Old Mar 31, 2004 | 10:18 AM
Nitro Dave's Nitrous Outlet's Avatar
I prefer wet kits.However if you are looking for a geat deal for your money,We have our dry kit on special right now for 450.00 with your choice of a 10lb or 15lb bottle.
Dave
Old Mar 31, 2004 | 11:33 AM
35th SS's Avatar
go for the 15pounder.thanks for the purge solinoid Dave.excellent customer service.
Old Mar 31, 2004 | 12:11 PM
aNuBiS's Avatar
Wink
Oh, and I need them by tomorrow!
</fastnfuriousquote>
Old Mar 31, 2004 | 03:34 PM
No problem,Thank you for all of your support.
Dave
Old Mar 31, 2004 | 04:08 PM
camaro98z28's Avatar
Just do a simple 100 shot Wet Kit. Dry Sucked
Old Apr 1, 2004 | 01:22 PM
Strahley's Avatar
No, he needs them by tonight!
Old Apr 1, 2004 | 03:40 PM
bad2000ss's Avatar
"You've got a heavy foot Brian, you'll blow yourself up."
Old Apr 3, 2004 | 04:56 PM
aNuBiS's Avatar
Talking
haha yeh, i realized that after i posted it, i was like, ah crap, it was by tonite.
thnx
Old Apr 6, 2004 | 01:22 PM
Strahley's Avatar
[ja rule]he got enuf naws to blow himself up, period![/ja rule]
Old Apr 6, 2004 | 05:34 PM
SDB's Avatar
SDB
just be careful with the nos...it can make the floor board bolts come loose under a 30 second hit, and make sure to monitor your laptop so you know when things get critical...and remember if your in a parking lot and someone yells "NOS"...run because that means someones car is going to blow up, and then these japanese guys will drive away on motorcycles.
SDB
Old Apr 6, 2004 | 06:11 PM
Strahley's Avatar
Also if whoever you are racing says "too soon junior," then you will lose the race and your dad's car. Or you will keep the car, but there will be two asians on dirt bikes shooting at you
