How is the halo bar installed?
Old Jun 21, 2012 | 03:34 PM
its turbo time's Avatar
Default How is the halo bar installed?
Just got my nitrous outlet halo bar in the mail and it came with no instructions.
Does the inlet go through the filter or the lid?
Any insight?
Old Jun 21, 2012 | 03:53 PM
Pewter53's Avatar
filter.
Old Jun 21, 2012 | 04:43 PM
Does a FTRA complicate that?
Old Jun 21, 2012 | 04:49 PM
Neal@NitrousOutlet's Avatar
yes it does go thru the filter .
Old Jun 21, 2012 | 04:53 PM
Nitro Dave's Nitrous Outlet's Avatar
The halo system is designed to have the nitrous solenoid mounted under the air bridge and for the feed hose to come up through the filter and connect to the Halo discharge bar.
The Halo bar will rest on top of the air filter under the air lid. The jet inlet fitting will be facing down and the flat tab will pinch between the air lid and air filter.
Dave
Opps.. Neal and I must have been responding at the same time. Atleast he had a picture..lol
Old Jun 21, 2012 | 05:13 PM
Thanks guy(s)!
Where do people usually mount the noids? Right now my hsw noids are on the battery bracket
Old Jun 21, 2012 | 05:27 PM
Is it possible to get a longer line for between the noid and the spray bar? That way i would not have to move it
Old Jun 21, 2012 | 06:20 PM
Pewter53's Avatar
i had mine hid by the horn flipped the horn and mounted it right beside it.
Old Jun 22, 2012 | 09:40 AM
You can mount the noid where ever you would like and yes we can build custom hoses to what ever length you need.
