Breaking up on 150 shot
How much timing did you pull?
Have u pulled the plugs to look at them?
I would post up pics of ur plugs after a 1/4 mile pass and we can point u in the right direction.
How do you know +2% fuel is enough? Do not spray it again on those plugs. Change to some br7ef's at the track and get a baseline.
Ditch the TR6's, put in br7ef's, drop down to a 100 shot and run it.
What other mod's do you have?
Even bone stock, running a 150 rwhp shot is pushing your stock fuel pump right to the edge of the "safe" limit.
Take a step back, call the guy's at nitrous outlet and get some experienced input on where to go from here.
The gap on a TR6 out the box is huge and most likely the reason you were breaking up.
But a BR7 in it, verify the gap is .035 and try it again.
Bro, you're super rich.
Take the 2% out, and jet down the fuel the next size jet you have. Rich is far from safe.
When you say stock timing as the tune ever been altered? It's been so long since I have seen a stock tune what is stock timing? 27*? 26*?
OP, DON'T DO WHAT I DID! Always check your plugs and make sure your timing is where it needs to be.
The TR6 if not gapped down can be a little wide for 150 shot. It could be blowing spark out. Definitely get those changed out to some BR7 gapped around 32.
Adding 2% fuel globally is most likely making you extremely rich when spraying.
Also stock fuel pump is good for 450ish whp. So if you are on stock fuel pump them most likely you are going to be on the edge of its duty cycle.
Do you have a fuel pressure safety switch?? if you do, the FPSS could be seeing that low pressure and grounding out the solenoids if the fuel pressure is dropping enough.
If you want help feel free to call us up or PM Chris, Dave or I.
If things are way of on a 50 shot you might not hurt anything, if it is way off on a 150 you might be building a new motor sooner than you thought.
I blew a motor up on a 150 shot. Lifted a ring land and cracked the cylinder wall. That motor was a stock bottom end pushing 571rwhp on a 100 shot. It was on barrowed time anyways lol.
At anything above that 200ish a B8EFS is what I always use and anyone else that frequents these boards.
Anything more than 250 I would seriously consider a B9EFS.
