Danger of spraying below 2500 rpms?
Thanks!
Josh
As far as spraying off the line...that would be your call. Ive seen people do it with a 125 shot and no problem, although they may have had a higher stall...but youd be walking a very fine line IMO and it would be a crap shoot. Youd be better off getting a progressive controller and dialing in half your shot or so for off the line and ramp up to %100 quickly. Brook(99Redhawk)...who took his stock shortblock very far finally blew his stock shortblock spraying like a 300 shot off the line. He shattered a few pistons and bent half his rods into the shape of a Z. Basically completely destroyed his motor. Of course he knew the chance he was taking beforehand.
<small>[ June 18, 2002, 07:29 PM: Message edited by: 383LQ4SS ]</small>
FoFo
'96 Corvette GS 'clone' 454
Tom
<strong>DONT SPRAY AT LOW RPM, FOR ONE N20 ADDS A HP THRU A JET WHERE 100 HP IS 150 TORQUE AT 3500 BUT YOU ADD 100 HP AT 1500 ITS LIKE 400 TORQUE YOU TRY TO INCREASE POWER THAT MUCH IN .1-.2 SECONDS YOU'LL START BENDING RODS OR CRAPPIN GASKETS, AND AT LOWER RPM THE CYLINDER PRESSURE IS HUGH COMPAIRED TO 3000-3500. 1500 RPM LAUNCHES ARE NOT WORTH THE ADDED TORQUE-VS THE COST OF VERY LIKELY ENGINE DAMAGE, I RAN A 250 -350 SHOT IN A SMALL BLOCK MY LOWEST RPM EVER WAS 3000 GOING FULL THROTTLE 1ST. DON'T LISTEN TO ANYONE WHO TELLS YOU TO SPRAY THE CAR AT 1500 THERE RETARDED</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Retarded huh <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
Like I said..3000 rpms is just a general rule of thumb. If we want generic info we would all run generic kits and follow generic rules. Theres alot more variables that will determine safe rpm to spray than just saying 3000 rpm is good and 2999 you blow up. The two main conditions that could be unsafe with spraying at a given rpm are obviously:
1) nitrous backfire which will damage various intake parts and is a fire hazard and
2) very high cylinder pressure which could exceed load limitations of engine parts
Variables that could lead to condition #1 are mainly:
1) size of shot
2) wet or dry
3) intake design
4) flow rate of intake charge (RPM)
Variables that could lead to damaged parts as a result of condition #2:
1) size of shot at given rpm
2) rpm shot is introduced
3) detonation (can occur at any RPM)
Yes theres more...but those are the basic variables.
So....first question...what are we talking about...wet or dry? Lets talk dry kit first, and we are talkin LS1 only here. I have never seen an LS1 dry kit have a backfire through the manifold. Never! Even 99Redhawk sprayed a large shot right out of the hole with no problems of backfire and I have sprayed 200 on many occasions. I think if the car is in good running order a dry nitrous backfire isnt a consideration. So then for a dry shot we are basically only worried about inducing high cylinder pressures by spraying too low in the rpms. What would be the safest shot at given RPM? There is no "magical" rpm number. If its ok to spray a 150 shot dry at 3000 rpm (as has happened many times) then what would be the lowest rpm you could spray a 50 shot dry? Certainly lower than 3000 rpms. Get my point? My new nitrous setup will be RPM based, and nitrous will start flowing below 3000 rpms..probably 2500. It will be a dry shot and ramp up from 0% at 2500 rpm to 100% at 5800 rpm and stop flow at 6400 rpm. It will likely be a 250 shot dry. So between 2500 rpm and 3000 I will likely see no more than a 40 shot or so ramping up from 0. Not unsafe IMO. Especially with a forged bottom end.
Ok...lets talk wet kits. Wet kits have all the consideration discussed above...but have the added problem of nitrous backfires. The LS1 manifold is not really that bad for spraying a wet shot. Its not the greatest...but people have regularly sprayed a 150+ with very few backfires overall. In this case the 3000 rpm recomendation is probably a good general rule of thumb. Just not worth the risk IMO.
If your just going to add an off the shelf nitrous kit to your car and not modify it then by all means...follow all the basic guidelines that came with the kit, nothing wrong with that. But there are lots of people out there that tweak and build and use progressive controllers and dual dry/wet stages and tweak shot sizes as well as activation points at 100 rpm increments and do all kinds of other stuff. In this case having a good understanding of the dynamics involved will come in handy. I dont want my knowledge of nitrous use limited to generic statements that come in the instruction pamphlet. I want to continue to learn so I can apply some knowledge to getting the most out of nitrous while doing so safely.
Al
<small>[ July 04, 2002, 08:55 PM: Message edited by: 383LQ4SS ]</small>
