NX switch panel and NX bottle heater problem....
Old Jun 21, 2002 | 11:57 AM
BIGBOS's Avatar
Default NX switch panel and NX bottle heater problem....
Well we got most of the stuff wired up....but we have the panel wired to an always on source so its running off the battery, but you still have to turn on the switch to activate the system...
The purge will activate no matter what... <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
And the NX bottle heater I got, the fitting that goes on the solenoid will not fit on to the end of my TNT bottle...any ideas??
Thanks,
Bos
Old Jun 21, 2002 | 08:38 PM
383LQ4SS's Avatar
Default Re: NX switch panel and NX bottle heater problem....
Im assuming that as soon as you arm the system the purge is opening? I am not familiar with the NX switches but maybe they have a normally open and a normally closed position. If this is true you can test it by arming the system and then push the purge switch and it should stop purging. If so switch the contacts on the back of the switch from NC to NO. But this is just a shot in the dark.
The fittings that wont fit? What size ans style are they. -4AN maybe or npt?
<small>[ June 21, 2002, 08:48 PM: Message edited by: 383LQ4SS ]</small>
Old Jun 21, 2002 | 08:50 PM
Country Boy's Avatar
Senior Member
I had the same problem with my NX bottle pressure transduser w/fitting. I had it screwed into a NOS fitting and upon removal, It stripped the NX fitting. I think their tread cuts are a little too tight.
Old Jun 25, 2002 | 11:28 PM
Black Sunshine/ 00SS's Avatar
Try running a tap threw the threads. I did, & changed the fitting off the bottle, that I believe caused it to strip in the first place.
Old Jun 25, 2002 | 11:37 PM
Bad Habit Bird's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BIGBOS:
<strong>
Thanks,
Bos</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">When you say the purge will activate no matter what do you mean that you can purge without the nitrous kit itself being activated?
Old Jun 25, 2002 | 11:43 PM
horist's Avatar
Brian, if you can figure it out by this weekend let me know... if you have the schematics (well.. even if you don't) we can figure it out
Old Jun 26, 2002 | 12:21 AM
BIGBOS's Avatar
The car can be off and the system won't even be activated, but I can still purge...
Its not that bad is it?
Old Jun 26, 2002 | 01:20 AM
All the NX switch does is complete the circuit to the purge solenoid so it will activate. So if you have the hot wire to the NX switch and that is an "always on" hot then you will be able to purge with the car and the system being off.
Does this make sense? or am I too tired <img border="0" alt="[boring]" title="" src="graemlins/gr_zzz.gif" />
Old Jun 26, 2002 | 01:25 AM
horist's Avatar
See... why must you go so complex? a nice home brew switch panel works fine for me <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<img src="http://www.horist.com/images/SwitchPanel/NewSwitchPanelDoneSmall.jpg" alt=" - " /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
