15# bottle in spare tire area?
Old Apr 25, 2004 | 03:22 PM
hawaiiboysz's Avatar
Default 15# bottle in spare tire area?
I'm new to this Spraying stuff im getting a F1 kit from a guy in town but his kit includes a 15lbs bottle will it fit in the spare tire area? I want to mount it between the rear seats but i dont feel comfortable w/ my son sitting right next to the bottle. I also want to keep the room in the back for my t-tops.
slow's Avatar
yes it will fit.
Ryan.
Old Apr 25, 2004 | 03:29 PM
PREDATOR-Z's Avatar
Was too tight for my taste. I put it in the back boot side ways and angled.
Old Apr 25, 2004 | 07:59 PM
pman's Avatar
Fits ...i mad a custom bracket off the threaded "jack" bolt down for my bottle
Old Apr 25, 2004 | 08:47 PM
pman got the capabilities to get a pic of how that bottle mounts (installed) and the mount. If possible send pic to rbisarra@yahoo.com. Thanks
Old Apr 26, 2004 | 08:09 AM
jamnut's Avatar
Here is a pic of a 15# bottle mounted in the spare tire area. It fits really nicely, you just have to watch how you orient the bottle & make sure that you have enough room to hook up your lines.
Old Apr 26, 2004 | 08:01 PM
pman's Avatar
I'll get a pic up tomorrow...for now if you can picture an "L" shaped piece of steel about 2.5 inches wide, about 4 inches tall and 1.5 in the bottom of the "L". It has 1 hole in the bottom for the jack mount and then 2 on the top for the bottle. The top has rounded corners to clear the carpet and plastic cover. I take the entire mount out every time i refill the bottle.
http://mywebsite.register.com/db2/00.../_uimages/Nos1
http://mywebsite.register.com/db2/00.../_uimages/Nos3
Old Apr 28, 2004 | 11:50 PM
SupahRich's Avatar
Great pics... they're exactly what I was looking for as well Using the hole where the jack bolted down is a good idea.
Old Apr 29, 2004 | 08:42 AM
Thanks Pman!!! Thats a lot of help. You should sell those things you could probably make some cash ola
Old Apr 30, 2004 | 09:20 AM
RedDemon2's Avatar
Nice Pics Of The Bottle Installation!
Old Apr 30, 2004 | 10:59 PM
Camaroguy's Avatar
If you have a bottle heater... where do you pull the 12 volt from ??.. Could it be pulled from the wires that are running towards the back? near the rear speakers.
Or do you have to run a wire up to the front PCM?
Old Apr 30, 2004 | 11:58 PM
pman's Avatar
I dont have a bottle heater but depending on how you want yours to work you would have to run a wire to you heater itself...either a switch wire that comes on when the ignition is on(same wire used for activation switch) or a switched hot wire(constant 12V) that is on all the time to make it able to heat the bottle between runs at the track without the engine on.
Old May 4, 2004 | 10:19 AM
kp's Avatar
kp
a few more pics, used some aluminum strap from a hardware store, took about 15 minutes to mount the bottle
