Introducing the Nitrous Outlet Puck System!!!
Old May 20, 2013 | 05:53 PM
brandon@nitrousoutlet's Avatar
Default Introducing the Nitrous Outlet Puck System!!!
Nitrous Outlet Nitrous Puck System
The Nitrous Outlet Puck system provides the most advanced method possible for single entry nitrous distribution applications. The puck is installed on the inside floor of the intake manifold. The puck has separate nitrous and fuel entry ports, each using its own tuning jet. The nitrous and fuel exit the Puck from separate discharge ports then collide creating a perfect atomized mixture that flows directly into each intake runner.
Construction
The Nitrous Outlet Puck is CNC machined billet aluminum , anodized black and CNC Engraved with the Nitrous Outlet logo. The Puck is designed to work in most carbureted intake manifolds and late model EFI carbureted style intake manifolds. The puck is custom flow matched and installed into the intake manifold at our shop. Installation of the puck does require custom machine work to the intake manifold.
How does the puck compare to our custom spray bars and traditional style bolt on nitrous plates?
A traditional style bolt on nitrous plate fogs the upper intake plenum. The nitrous and fuel mixture are pulled into the runners based on airflow, possibly causing an uneven distribution cylinder to cylinder. Our custom spray bars are machined into the center of the intake plenum and the discharge pattern is specifically matched to the intake runners allowing us to control the atomized mixture of nitrous and fuel to each cylinder. The one thing a bolt on plates and spray bars share in common is that the nitrous enters one end of the bar and slams into the opposite end. As a result the discharge volume on the opposite end of the spray bar or plate can be slightly greater than the end it enters.
While our custom spray bars are much better than a traditional style bolt on plate, the puck is the next step to a more controlled discharge delivery. Due to the pucks design we are able to deliver a more controlled discharge across all 8 cylinders without going to a traditional style direct port system.
How do I get a Puck?
Orders for the Nitrous Outlet Puck are similar to our spray bar and direct port installation process. You will need to contact a Nitrous Outlet sales representative. The sales rep will build you a quote based upon your needs and intake manifold. The sales rep will then provide you with a fabrication order number to write on the box when your intake manifold ships to Nitrous Outlet. If you do not already have an intake manifold we can provide one to you. Once your intake arrives to Nitrous Outlet the sales rep will contact you to fill out a custom build sheet and go over any final details. When the fabrication department and intake specialist are finished building your system the sales rep will contact you to finalize your order for shipment back to you.
Follow these links for video of The Puck!:
Old May 20, 2013 | 06:05 PM
Beatdown Z's Avatar
That is COOL!
Old May 20, 2013 | 07:13 PM
SuperSlow02's Avatar
way to be innovative!!!!! hows the price comparied to a DP system?
Old May 20, 2013 | 07:48 PM
Carter01's Avatar
This is soooo sick! Way to be innovative and always striving to set the bar high!
Old May 20, 2013 | 08:56 PM
loosews6's Avatar
hands down bad as fu** will be calling tomorrow to get one...off with the induction solutions plate in with nitrous outlet puck..............
Old May 20, 2013 | 09:40 PM
krissoto's Avatar
Seems like a pretty sweet system.
Old May 21, 2013 | 12:38 AM
01SOMZ28's Avatar
That is 100% bad-******-***. I'm putting a carb'd 6.0 in my '52 Bel Air coupe....I could see a lot of butt-hurt being made with this
Old May 21, 2013 | 06:32 AM
Charles Cyrus's Avatar
Very Nice!!!
Old May 21, 2013 | 08:49 AM
boostit5.3's Avatar
so much win in one post! and its kinda hidden too lol
Old May 21, 2013 | 09:10 AM
The Puck is considerably less.
It can be VERY hidden!
Old May 21, 2013 | 10:50 AM
Silver408z's Avatar
Does it work on a fast?
Old May 21, 2013 | 10:53 AM
This is only for carb-style intakes as of now.
Old May 21, 2013 | 10:56 AM
Detoxx03's Avatar
Great innovation.
Old May 21, 2013 | 11:01 AM
Rise of the Phoenix's Avatar
I love seeing stuff like this. You guy's are the best.
Old May 21, 2013 | 11:07 AM
Thanks guys!
Old May 21, 2013 | 11:19 AM
alans02z's Avatar
That damn s10 is getting **** handled. Completely awesome guys
Old May 21, 2013 | 12:35 PM
navyblueSS's Avatar
Awesome!
Old May 21, 2013 | 05:25 PM
Heavy H.P.'s Avatar
Now this is nice.
Old May 21, 2013 | 06:58 PM
Blackpanther99's Avatar
Something very new and sneaky Great way to step up the game guys.
