ANYONE USING IRIDIUM PLUGS W/ N2O???
Old Oct 26, 2002 | 08:10 PM
CAT3's Avatar
Restricted User
Default ANYONE USING IRIDIUM PLUGS W/ N2O???
My friend said as long as you go colder than stock, ther good. I dont like the idea of cramming my meat beater inbetween all the EGR sh*t every time I wanna change out some TR6's cause they dont last. Let me hear ya. TIA.
Old Oct 28, 2002 | 07:31 AM
PewterZ's Avatar
Default Re: ANYONE USING IRIDIUM PLUGS W/ N2O???
My TR6'S have lasted 21,000 miles...And it's been sprayed the last 5K.Not one has even burned up.Who says TR6'S don't last.
Old Oct 28, 2002 | 08:58 AM
ls1290's Avatar
Dumb Ass Vette Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by PewterZ:
<strong>My TR6'S have lasted 21,000 miles...</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Dude, when not at the track swap those TR-6 out for TR-55!!! When running N/A with TR-6 in the car, I lost about 40 rwhp because they run so much colder. Having two sets of plugs and changing them out at the track is a PITA, but well worth it <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Oct 29, 2002 | 12:55 AM
CAT3's Avatar
Restricted User
Don't get me wrong guys, I am not trying to discredit anyone, rather gain knowledge. A few of my friends run TR6 plugs, some change out @ 12,000 miles or so, others only spray once in while and go longer. I read the Colonel reply about increasing gap to i believe . 035 w/ tr6 so you dont loose any power off the spray. But I would like to know if anyone has success running iridium plugs, whether they "lost" power off the spray due to colder plug, and how long they used the same set of plugs. I would like to be able to put iridiums in, run them daily and spray week-endly and not have to change the bastards out every 6/8 or 10 months. No way in hell would I go through the BS to change plugs out Friday after work and back Sunday just to spray on the week-end, not for this kid. Maybe if I had headers and EGR, Air delete, but with all that shant I'm looking at changing as little as safely possible. TIA.
Charlie.
Old Oct 29, 2002 | 01:02 AM
35th SS's Avatar
hey charles get some headers already.those stock manifolds gotta go.also changing plugs is a piece of cake.you can do it.if you need help let me know. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Oct 29, 2002 | 01:27 AM
CAT3's Avatar
Restricted User
When my perctionistic *** can make my mind on exactly which headers and which exhaust, I will buy them. As for the plugs, yeah, did some more research and will try to pick some up and throw them in friday, i get off work early. TR6's, seeing how I think I can get the plugs changed in 2 hours or less, yes on the first time. I might go get a quote from Robert in kailua on my exhaust system, flat pipe like the Bobby Lee's (?). I will be ordering Nitt's friday, wish someone on island carried the right size. Hey, I got a really small surging going on when in gear at idle, but not in neutral or park at idle. It did this a couple times when the EGR was leaking, but more of a pronounced surge. Now, it is very slight, just enough to get the sh*tty factory tach to swing from like 490-540rpms. No SES. What do you think. Thanks Rex.
Old Oct 29, 2002 | 03:00 AM
383LQ4SS's Avatar
I still dont know anyone using them with nitrous. However the turbo cars are having great luck with them. If I had to guess I would say yes they could be used with nitrous. Will they give better performance? I have no idea. Will they hold up longer than copper...again...no clue. As soon as the motor is back together im gonna give some a shot and see if they hold up to a decent size shot.
Old Oct 29, 2002 | 03:26 AM
35th SS's Avatar
if I had to do it over again on my 98z.I would go hooker LTubes/Dr.Gas x-pipe w/bullets on each pipe and some turndowns or dumps.wont go pass the rearend.awesome setup.couldnt pass up the deal on my borla for 400.00 dollars.bob lee got those custom made with robert in Kailua.like nascar pipe.sounds good at idle but wide open sounds like a harley motorcyle.didnt like it.about plugs changed mine sunday to tr6 gapped@ .035 took me about 2hrs.still have to change my belt tensioner maybe tomorrow afterwork.will be ready by fri.and maybe throw in a gal.of 103octane racegas. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Oct 29, 2002 | 05:17 PM
ls1huntr's Avatar
Closed ex-Sponsor Account
You can use iridium spark plugs with a nitrous application. They are actaully recommended to use with any power adder (i.e. turbo, supercharger). The reason being is they can withstand higher cylinder temps and higher cylinder pressure for instance Iridium is 6 times harder, 8 times stronger, and has a melting point 1200 degrees higher than platinum.
<img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" /> TNT <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" /> NX
Old Oct 29, 2002 | 05:45 PM
PewterZ's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ls1290:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by PewterZ:
<strong>My TR6'S have lasted 21,000 miles...</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Dude, when not at the track swap those TR-6 out for TR-55!!! When running N/A with TR-6 in the car, I lost about 40 rwhp because they run so much colder. Having two sets of plugs and changing them out at the track is a PITA, but well worth it <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have done that...but you're right it is a PITA. I also lost about 35 hp with TR6'S NA. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Old Oct 29, 2002 | 05:48 PM
CAT3's Avatar
Restricted User
Which iridiums are recommended by those that use them with N2O? I thought that iridium sounded about right, but then until last year I thought platinums where the best for the same reasons, longer life and wear resistance than copper etc...TIA.
Charlie. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Old Oct 29, 2002 | 06:41 PM
LS1x2's Avatar
Formerly 4mulaJoe
You guys actually dynoed and saw 35rwhp less with the TR6's vs stock?
Old Oct 29, 2002 | 06:48 PM
BADZ's Avatar
Moderator
Car's run so much better on a hot plug n/a, Now don't quote me on the hp's but if your running a nitrous set up with cold plugs then your straight but running the same plugs n/a your going to lose hp's across the board... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Oct 30, 2002 | 12:21 AM
CAT3's Avatar
Restricted User
REX, what was your 60' on the "street" tire pass? I'm real close to yours, mines in the sig, plus your street tires are much more aggressive than mine. Seeings how I have the A4 I am about maxed out at 13.2, unless I get a good 60'. Now you have the M6, so you got quite a bit left in her, plus you realllllllllly NEED to tune her, she'll thank you for it. Ok, I didnt get to hear Bobby's car at WOT, so you may have a point. This is why I am undecided as of now. My alternate plan includes Hooker LT's, ORY, feeding stock exhaust with my cutout and changing my tips tot he SLP Quad tip, Possibly having Robert put in a bullet and then make a Y for the rear exiting into the quads. I can handle near silence on the street, then the beutifully crisp sound of the cutout (BTW my neighbors noticed the cutout at like 2 in the morning-early day of work ooops.) Whats up w/ your belt tensioner-obviously going bad huh? Any idea on the surging problem-read up a post or check external category???? hit me back. Charlie.
Old Oct 30, 2002 | 06:56 AM
BensZ28's Avatar
Any plugs out there that would be safe for n2o 100shot but retain as much hp as stocker plugs?
Old Oct 30, 2002 | 09:52 AM
NoGo's Avatar
My car is a turd, but I have never seen a large noticeable difference on the dyno when switching from a hot to a cold plug for my NA dyno's.
This may be offset by the mild KR I get though with the hotter plugs.....
Just my .02
Old Oct 30, 2002 | 03:27 PM
BensZ28's Avatar
Over stock there shouldnt be a change?
Old Oct 31, 2002 | 12:38 AM
ls1290's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 4mulaJoe:
<strong>You guys actually dynoed and saw 35rwhp less with the TR6's vs stock?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes. TR-6 vs. TR-55.
Old Nov 2, 2002 | 05:52 PM
Ravenous T\A's Avatar
What is the part # for the IRIDIUM plugs to use?
Old Nov 2, 2002 | 07:01 PM
99 Black Bird T/A's Avatar
I dyno'd my car with TR-6 and TR-55, the TR-6 lost 6rwhp. With the MAFT I leaned the car out 2 percent at WOT and got the 6rwhp back.
My gas mileage dropped with the TR-6, about 3 mpg less.
New TR-55's went back in,
