My nitrous install thread...!
Old May 17, 2014 | 09:30 PM
  #61
pewtered'Z's Avatar
Very nice
Old May 18, 2014 | 05:08 PM
  #62
Blown383LS1's Avatar
Very nice install to say the least.
Old May 18, 2014 | 06:19 PM
  #63
slammin86's Avatar
Made decent progress today. Jesus christ I hate being ****.
Old May 18, 2014 | 06:27 PM
  #64
slammin86's Avatar
Originally Posted by pewtered'Z
Very nice
Thanks guys.
Old May 20, 2014 | 08:29 PM
  #65
BigEd_72455's Avatar
OK, now take the glove box back out and get rid of those UGLY plastic crimp on caps and put some heat shrink on the wires. It looks like a rainbow threw up on those things... LOL
By the way, nice clean engine. I wish my S-10 engine was that clean on ANY part of it..
But, it wont be...
Old May 23, 2014 | 09:05 AM
  #66
slammin86's Avatar
But, it wont be...
That is actually on my long list of things I still need to do. I agree it is an eye sore on such a clean install and it will be addressed.
Old May 23, 2014 | 11:19 AM
  #67
Zmg00camaross's Avatar
Great work. Soon will be doing this myself!! You have a ET goal? Or mostly street drivin.
Old May 25, 2014 | 11:56 AM
  #68
slammin86's Avatar
Made a little bit of progress the last few days. First I could not deal with what I created in the glovebox...all of the different color wire terminal ends. So I took it all apart and cut those off. I re crimped on the ends after removing the colored plastic crap. I then covered everything with heat shrink. The results speak for themselves.
Now for the real progress. I got the mainline ran from the trunk to the nitrous solenoid. I also got the fuel line ran from the rail to the fuel solenoid.
I then finished all of the wiring in the trunk. This includes the 3 quick connect terminals. Also got all of the wiring done on the bottle and heater. Made the trunk ground and covered it all with loom. And lastly I drilled the holes in the trunk for the bottle bracket/ heater combo. I decided to install jacknuts in the trunk so that I can use the same fender washers that I have under the hood. Unfortunately I only had one jacknut left but have more on the way.
Oh, and I put in the 50hp jets.
What's left.
Spark plugs
Wire up everything under the dash to the terminal strips.
Run main power from battery.
Run leads to nitrous and fuel solenoid as well as purge...and figure out a ground under the hood.
Tap into tps and tack under the dash.
Install 2 more jacknuts.
Cut out trunk carpet to have a clean bottle install.
Old May 25, 2014 | 11:58 AM
  #69
slammin86's Avatar
I want to see mid 11's on motor. I know I have the power for this but really doubt I will be able to get the 60's needed.
On spray if I cannot get into the 10's something went wrong.
Ultimate goal is 135 traps.
Old May 25, 2014 | 01:10 PM
  #70
Roger that! Sounds good.
Old May 25, 2014 | 01:45 PM
  #71
BSmiff's Avatar
You should pick up right at 11 mph on the 100 or maybe a 125 shot. Once you get into the big boy jet you should be able to mph your way into the low low 10s for sure.
Old May 25, 2014 | 02:24 PM
  #72
BSmiff's Avatar
This is EXACTLY how a clean nitrous install should look. There is no need for it to look any other way after seeing this. Thank you for this thread bro.
Old May 26, 2014 | 02:07 PM
  #73
slammin86's Avatar
Spend a few more hours on it this morning. Got the br7 plugs gaped to .35 and installed.
Tapped into the tps and tach in the drivers kick panel...most of the guys just pull this from under the hood.
Also got the wiring under the hood done. I installed loom on the passengers side injector harness and ran the solenoid(s) ground inside of that upto the passengers side head. Ran all of the wires into the cabin on the passengers side firewall. Also installed main power to the battery ran into the cabin.
At this point all that is left is to install 2 jacknuts in the trunk to mount the bottle, cut the carpet out in the trunk to fit around the bottle mount. Wire everything upto terminal strips in the passengers side floor board, and figure out my purge.
Puttin in the 50 shot jets yesterday really motivated me to get this bitch done. The end is in sight.
Old May 26, 2014 | 02:08 PM
  #74
slammin86's Avatar
Old May 26, 2014 | 02:10 PM
  #75
slammin86's Avatar
Yep
I would like to think that 120 traps are achievable on motor with the head swap and gears.
Thank you. I set out to do something that I have not seen done before on several levels...so far I have achieved it.
Old May 26, 2014 | 02:21 PM
  #76
slammin86's Avatar
I also came up with a cheap approach to traction...that should look good as well.
Notice how they look similar to the vmr's. I also painted them to get them to match a little better.
The color match isn't perfect but when you get some distance between them it is acceptable.
Old May 26, 2014 | 02:24 PM
  #77
slammin86's Avatar
Also did a single 4" exhaust.
Old May 27, 2014 | 12:46 PM
  #78
Rise of the Phoenix's Avatar
Nice find on those wheels. Pretty damn close to what's on there now in terms of looks.
Old May 27, 2014 | 06:20 PM
  #79
slammin86's Avatar
Installed jacknuts in the trunk and am using the same fender washers to hold the bottle bracket that I have everywhere under the hood. Because showcar.
Old May 27, 2014 | 09:05 PM
  #80
slammin86's Avatar
Got bottle in...super happy with how this came out.
Make template.
Cut holes in template.
Transfer holes to bottom carpet...make removable.
Install bracket.
Install bottle.
Stand back and take picture.
I am going to tweak the wires back there a bit but for now it is good.
All thats left is to wire everything to terminal strips under the dash. Then cross my fingers that I got all the wiring right. Nothing has been tested along the way.
