who's all running the nitrous outlet puck?
im thinking of getting the puck for a second stage I have a steve Johnson plate now leaving on 300 off brake been 5.64 at 121mph with 1.24 60ft... how does everyone like the pucks tune up and over all performance..
Just for a reference I just sent my intake back to Dave to remove spray bars and install the puck. I won't be up and running for a while but it is a proven piece so far and the results I have seen caused me to change up.
Yeah, saw the Z on AZFT. I don't think the design of the Whipple will allow the spray bars to be installed...?
I've seen the direct port photos on FB that NitrousOutlet has done on a Whipple and Lysolm but was thinking the puck would be an easier install and less permanent.
Not soo sure about a plate pre-boost, after the TB. But obviously the easiest and cheapest route.
Still on the fence but, gathering some info.
I did not see what was so custom about that bracket where holes were offset drilled after bracket was cut. Similar plates like the one I got can be purchased from Summit, Jegs or EBay for around $50- $100.
Okay then, I will pay you another $100 for bottle, and both solenoids right.
Let me know how you want the payment
You said earlier it $25 to bend hard lines. So what you are telling me bracket is worth more than bottle, fuel solenoid and nitrous solenoid combined? How much did you charge me for the bracket? You have the invoice, don't you?
