Help reading plugs...
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
If you change that plug and it comes out with the insulator colored up like that while the others are clean, I would start by replacing that wire and/or doing an ohms check on that wire. If that does not fix it, perhaps a leaky or stuck injector. If that is not it, then maybe a problem with that hole.
That is where I would start.
Does it get to 12.0 and hold it there? Where is your 02 sensor? full exhaust?
We ran ours at 12.8 most of the time.
Clean plug make for a happy engine.
You will hurt more parts being too rich than you will too lean.
