50 shot on ls3 with 26* of timing...
Old Sep 2, 2014 | 04:31 PM
Sk8phreak88's Avatar
Default 50 shot on ls3 with 26* of timing...
I'm having issues with getting my "timing tuner in a box" to work on my car. I'm going to the race track and don't have the time nor the coin to buy a new controller before this weekend. The car is a cam, headers, 92mm throttle body. The car is currently tuned with 26* of timing. I'd like to spray at least something to get anything extra I can. Curious if running a 50 shot on the car would be ok or advised against completely.
Nitrous setup is just a wet single stage nozzle in front of the throttle body.
Old Sep 2, 2014 | 05:32 PM
HCI2000SS's Avatar
Probably okay, but there's always a risk when cutting corners. What plugs are you running and what fuel system?
Old Sep 2, 2014 | 05:58 PM
Thanks for the reply. My system is a aero motive 340 with stock lines to stock ls3 (42lb) injectors.) was thinking if mixing 50/50 100 octane and 93 for insurance.
I'm installing a set of NGKbr7ef's as I type this.
Old Sep 3, 2014 | 08:51 AM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
We recommend pulling 2* per 50hp from factory timing. With the timing already advanced, I would be careful spraying on that. Better to be safe and tune back into it.
-Garrett
Old Sep 3, 2014 | 09:02 AM
brandon@nitrousoutlet's Avatar
Do you have HP Tuners or EFI Live or have access to either? We could always next day you an lnc-2000
Old Sep 3, 2014 | 02:08 PM
I don't really feel like buying the credits for my buddies hp tuner. I wish I had the coin to have an lnc overnighted. I think what's going on his my timing tuner box doesn't like the signal from the 24-58x converter box in my car.
Old Sep 3, 2014 | 03:01 PM
ZackMorris's Avatar
Doing it properly will cost less than replacing engine internals.
That being said- you're probably fine on a small 50 shot. Probably.
Old Sep 4, 2014 | 09:59 PM
Sorry, that didn't come off right. What I meant by not wanting to spend the $100 on credits is because I've already paid my tuner the coin to unlock my ecu. But I wasn't able to meet up with him to pull the timing out for the weekend. I guess we'll see how this weekend goes if I say to hell with it and pay someone at the track to unlock it and pull some timing. Thanks for all the replies guys.
Old Sep 5, 2014 | 08:48 AM
No problem. Let us know if you need anything else!
-Garrett
