370 nitrous build
Lq9 iron block
Bored to 370
Stock crank
Stock rods
Wiseco flat tops
Prc as-cast 225 heads
I may do a decent set of H beams depending on the budget
Victor jr efi intake
4 barrel throttle body
I will get a cam specific for this setup
Th400 rmvb with brake with a stall specific for this setup
Arp rod bolts and head bolts
All this ran with holley hp efi
This will be in a 88 mustang coupe 3050 lbs with me in it. Plan on hitting with a 200 shot throw a plate kit. How does this sound. Called Texas speed today. With the wiseco flat tops and with the 225 as-cast, compression should be around 11.3-1. What do yall think?
Lq9 iron block
Bored to 370
Stock crank
Stock rods
Wiseco flat tops
