Throttle Cable Extension Bracket for 04 GTO
Old 01-14-2016, 01:55 AM
Chevy_Ss's Avatar
Default Throttle Cable Extension Bracket for 04 GTO
Hi ,
My problem is that the car is not going full throttle after installing the NOS plate kit due to cable is not fully extended .I tried to move the OEM bracket forward but then Idle won't be accurate .Long story short the cable either not fully extended or not fully retracted. I lost the Throttle Cable Extension bracket which came with NOS Kit .As per Summit racing P/N 49R2095 discontinued. I'm trying to find anything that could help my case or any dimensions to fabricate it locally .Any alternative solution ?
Thanks
Old 01-14-2016, 10:30 AM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
Hope this helps
-Chris
Old 01-14-2016, 01:22 PM
Chevy_Ss's Avatar
That's great help Chris .Can you send me the holes location and dimensions if possible .I know I'm to greedy .Are you selling this particular piece ?
Old 01-14-2016, 01:24 PM
-Chris
Old 01-14-2016, 01:27 PM
Counter sunk hole bolts; M6-1.0 x 10
The other holes you'll reuse the factory bolts.
-Chris
Old 01-14-2016, 02:03 PM
Chevy_Ss's Avatar
Great info man.I really appreciate your help.
Old 01-14-2016, 02:15 PM
Chevy_Ss's Avatar
So we are talking about 0.79 in of shifting from the original position.
Old 01-18-2016, 09:18 AM
AJatNitrousOutlet's Avatar
If you need a throttle relocation bracket give me a call. Ours are 14.99-
Old 01-22-2016, 12:48 PM
Chevy_Ss's Avatar
OMG I just saw this message I just placed my order with other vendor
Old 01-22-2016, 01:54 PM
It's cool, hit me up if you need anything else!
Quick Reply: Throttle Cable Extension Bracket for 04 GTO
