How much should I spray?
Lunati voodoo crank and rods
CP Bullet forged flat tops (ring gap for n/a)
ARP rod bolts
AFR 230cc heads
Cometic .040 head gasket
ARP Head bolts
FAST 102 throttle body and manifold
11.75:1 comp running e85 fuel
I was looking at n2o outlets hardline plate system and a progressive controller for a simpler install but not opposed to a direct port setup if that's the way to go. Thanks!
Was hoping to run at least a 100 shot and go from there. Size of the shot will depend how close to a 10 second quarter I can get n/a.
I pull 9 degrees out, soft tune, good gas, and correct plugs. Can't really mess up.
car picks up 20mph when sprayed.
