Kr
Old Jul 30, 2004 | 08:20 PM
2002$$'s Avatar
Default Kr
dude i dont know what the hell is up.ok my local speed shop guy told me 2 up my fuel jet to try and get rid of detonation...sooo i got rid of det. but now im getting more knock retard.will 106-octane fuel get rid of kr? no,right?itll only get rid of detonation, right?
Old Jul 30, 2004 | 09:19 PM
tonyt123blue's Avatar
I thought knock retard as caused by detonation,if you get rid of detonation there should be no retard.
Old Jul 31, 2004 | 12:21 AM
2002$$'s Avatar
well the pause when i spray is gone....spray,pause,spray.....but im gettin major KR...how can i fix it other than tt or dyno-tune...high-octane fuel?
Old Jul 31, 2004 | 11:58 PM
2002$$'s Avatar
any1 else?
Old Aug 1, 2004 | 07:59 AM
jamnut's Avatar
It's very hot these days, you live in California, it's hot there. Where I live on a hot day some cars will start getting detonation with a stock tune on our 93 octane we get here. If I remember correctly you showed your settings on your TT were like +1 base & +2 over 3k rpm's. So you are adding timing during the worse time of the year & maybe not pulling enough timing on the spray to compensate.
I have my TT set at 0 & 0 & am only using it to pull timing on the spray. Maybe this fall & winter when my DA gets low and some times it's even in the high negatives then I'll be adding much timing according to ATAP.
Old Aug 1, 2004 | 08:20 PM
2002$$'s Avatar
not using tt.its messed up rite now,im gonna call dave@ramchargers tomorrow to get some help.but im just wondering if high octane fuel will stop KR?
Old Aug 1, 2004 | 10:33 PM
2002$$'s Avatar
any1?
Old Aug 2, 2004 | 07:57 AM
jamnut's Avatar
How do you know you have gotten rid of your detonation if you are still getting KR? You are spraying a wet shot, so it's not getting Burst KR due to spraying a dry shot through the maf. So you must be getting some kind of knock for your car to be pulling timing.
Old Aug 2, 2004 | 08:12 PM
2002$$'s Avatar
actually i dont know,but the pause is gone now that i richened the fuel jets 2 sizes.but the other night at the races i sprayed at nighttime and it was a lot better. knocked a lil maybe once or twice, but better at night.must be the heat, right jamnut....btw thanks for all your help,dude.
Old Aug 2, 2004 | 08:13 PM
2002$$'s Avatar
do you have to have a laptop to use atap?
Old Aug 3, 2004 | 07:23 AM
jamnut's Avatar
It takes a laptop to run ATAP.
Old Aug 3, 2004 | 06:11 PM
2002$$'s Avatar
hey jamnut....i found out what was wrong with my tt!!!i called mike at the place that makes them.i had the ground for my solenoids and relay tied toegether!!!weak,huh.so i separated them and just put relay ground on tt.im gonna go test it right now...ill let you know.
Old Aug 3, 2004 | 07:07 PM
2002$$'s Avatar
i hooked it back up(the right way,lol.)and it works fine.good thing i did'nt fry it. but i think it wasnt running optimum(rich fuel)because my speed shop guy told me to richen fuel jet, to compensate for detonation.i thought it seemed a little rich.i only took 2* of rtd,and i was wondering what the heck was going on.but its all good. hey jamnut what kind of temps do you have where you live?and how much rtd do you use?btw....no base and no wot advance,right now im at 0,0,2rtd.thanks dog.
