How bad for the motor is it?
Old Aug 25, 2004 | 02:41 AM
  #61
Jimmy Smits's Avatar
Originally Posted by Magic Chicken
Go squirt a water hose and come talk to me, let me know how it works.
You go spray a hose with a nozzle attachment. Now spray the hose on full pressure (a maximum amount of water is allowed pass the nozzle). Now if you could somehow increase the pressure 10x's, the same maximum (assuming the maximum was achieved the 1st time) will be allowed out, now the hose will expand or explode due to the added pressure, but the same amount is still only allowed pass the nozzle. The nozzle will only allow a certain maximum amount of water out of the hose, because it regulates it.
Old Aug 25, 2004 | 08:56 AM
  #62
tooquick2beslo's Avatar
ok i would really like to know who is correct on this debate.....
Old Aug 25, 2004 | 09:47 AM
  #63
MilDot's Avatar
So the debate is:
Does pressure affect volume when the hose opening is partialy restricted?
Is that accurate?
Old Aug 25, 2004 | 10:37 AM
  #64
MilDot's Avatar
Spoke with a friend who is a science teacher...
She said that the waterhose analogy is not quite accurate due to liquid vs. gas...whatever...
The opening in the orifice (jet) is smaller than the opening at the bottle. Once the maximum flow from that orifice is reached back pressure will begin to build in the hose until it eventually blows apart. That is not to say it will blow by 1500 psi but it will eventually blow...spraying nitrous into the engine bay.
Now, will a given jet flow more at 1500 psi than it does at 1100 psi? Probably so, I dont know. It should continue to increase the amount of gas released until it reaches max. and back pressure starts to build. If 125 was the true max I would think that everyone who accidentally overheated a bottle would be blowing nitrous lines. In other words there might be some safety margin built into those ratings. Not saying that the jets are over-rated just that a jet capable of flowing 125 at 1100 might flow more with increased pressure until it starts to build backpressure.
Old Aug 25, 2004 | 10:41 AM
  #65
Deckhand's Avatar
I wonder at what PSI do the jets reach maximum flow
Old Aug 25, 2004 | 10:43 AM
  #66
Magic Chicken's Avatar
12 Second Truck Club
Nitrous is in liquid form in the bottle then it is atomized at the nozzle. Granted there is some in gaseous form, but when you get down to that your HP is greatly decreased.
Old Aug 25, 2004 | 12:05 PM
  #67
FYI, take it for what it's worth.
I just got off the phone with NOS, NX, Nitrous Works, and 2 local speed shops. They all say more pressure = more nitrous. The companies that make your jets said this, if you choose not to believe it, be my guest. Call them yourselves. Doesn't matter if you're running wet or dry, more nitrous pressure = more nitrous to the engine. NOS even said that if you're jetted for a certain HP with a specific solenoid and you change the solenoid to one that flows more, you will be spraying a bigger shot through that same jet.
I will also go so far as to say yes, there is a maximum pressure at which a jet will not flow any more nitrous, but it's not in our operating range.
Can we end this now? I'd hope 3 manufacturers of n2o systems and 2 speed shops know what they are talking about, after all we use their products.
Old Aug 25, 2004 | 12:35 PM
  #68
Deckhand's Avatar
sounds good to me.
Old Aug 25, 2004 | 01:13 PM
  #69
MilDot's Avatar
damn chick'n.
I hope you didn't think I was disagreeing/arguing. I just thought it was a really interesting question...
Old Aug 25, 2004 | 02:28 PM
  #70
damn chick'n.
Sorry, I didn't mean to come off argumentative or anything on that. Just wanted the facts straight.
Old Aug 25, 2004 | 06:49 PM
  #71
So say I had my bottle at 1500 psi on 125 shot jets, would I be spraying like a 150 shot then ?
Old Aug 25, 2004 | 06:55 PM
  #72
Not sure what the final outcome would be, but according to 3 n2o manufacturers and 2 speed shops, you would be spraying more than 125. Take it to the dyno. If I had 2 bottles I would have no problem going to the dyno and trying this.
Old Aug 25, 2004 | 08:51 PM
  #73
Very interesting. Thanks for the info.
Old Aug 26, 2004 | 01:12 AM
  #74
00Pontiac's Avatar
trying to move on here...
I'm interested in a n20 system, but what about nitrous fires? you see or hear of them often enough. the possiblility of having one at some point makes me hesitant...
Old Aug 26, 2004 | 01:15 AM
  #75
Nitrous itself isn't flamable.
Old Aug 26, 2004 | 01:29 AM
  #76
00Pontiac's Avatar
well sure I understood that... but I've seen several "nitrous fires" happen on cars at the track, that's what I was curious about, because I know n20 isn't flamable in itself.
Old Aug 26, 2004 | 01:33 AM
  #77
I personally have no experience with "nitrous fires" myself, so I guess that's as far as I can comment. I have theories, but I don't want to post about something I'm not 100% sure on.
Old Aug 26, 2004 | 03:41 PM
  #78
5POINT7's Avatar
Chicken, that was an interesting debate. I'm joining late I know, but one can't help but wonder what Jimmy Smits has to say now?
Old Aug 26, 2004 | 03:58 PM
  #79
I'm sure something to the effect that the 3 n2o companies that make n2o systems and jets are wrong and 2 speed shops that sell the stuff and dyno tune vehicles with nitrous systems are wrong too. He has too much invested to back down. It doesn't really matter to me what he says anymore, I know the answer. This debate should be over now, I know I'm done with it.
PS. For further debate please call the following:
NOS - 270-781-9741 option 5
NX - 940-767-7694
Nitrous Works - 706-864-8544
Le-Toy Motorsports - 661-396-8100
Speed Engineering - 559-348-0200
I had no idea until just now, but Speed Engineering is also a sponsor of this site.
Old Aug 27, 2004 | 02:16 AM
  #80
Here's what I have to say, and I've said it like 100 times in this thread. Tweety Bird is incorrect in his statements. A dry kit jetting to 125 hp, will not all the sudden make 150 hp when the pressure goes from 1100 to 1500. Therefore, toasted chicken is wrong... (and you don't need to monitor a dry kit's increased pressure over a wet kits - his initial false statement)
There is no doubt, and no one is arguing that pressure does not effects hp, that's a given (until the maximum flow is achieved). Tweety bird says on a dry kit, when the pressure gets to 1500, your 125 jets magically turn into 150 jets. Re-read all the posts from start to finish, I am 100% correct in my statements.
