Bottle pressure after refill
Old Sep 14, 2004 | 01:36 PM
bsmith98's Avatar
Question Bottle pressure after refill
I have only had my bottle filled up once, and i was wondering if i got screwed on my fill or not. When i got the bottle filled it only showed 950 psi, i was just wondering if this was right. I have been running the 75 shot and i have only done like 8 full runs, and i only have 750 psi now. The bottle seems kinda light. So i was just wandering if i got screwed on the fill or not.
Old Sep 14, 2004 | 03:22 PM
Nitro Dave's Nitrous Outlet's Avatar
The best way to tell is to weigh your bottle.
Dave
Old Sep 14, 2004 | 03:43 PM
GM Muscle's Avatar
Your probrably getting empty. It's hard to hold the bottle above 850psi with just a couple of pounds in it. Do you own a bottle heater? That's the only good way to control the bottle psi.
BTW: Right after I refill a bottle the pressure will be anywhere from 900 -1300psi depending on the tempeture (will be even lower if I freeze them first). You can't really religh on pressure to tell you just how much is in the bottle
Old Sep 14, 2004 | 08:09 PM
firehawk00's Avatar
You probably didn't get screwed on your fill. My bottle usually shows about 700-800 right after a fill, like that because the bottle's cold after a fill. Depending on the outside temp, you should be able to see 900-1000psi on a full bottle without a bottle warmer (during summer). If you don't have a bottle warmer during winter time, you will have trouble getting your bottle to optimum pressure. Nitro Dave's right, best way to tell is to weigh your bottle.
Old Sep 14, 2004 | 11:57 PM
Ed Blown Vert's Avatar
Actually your bottle should be pretty warm after a fill. Mine will get up to 1000 psi after one.
Old Sep 15, 2004 | 08:35 AM
jimmyblue's Avatar
Moderator
A bottle with any liquid left, will see its pressure
depend only on temperature (vapor pressure @
temp). You have to go by weight to know the
quantity of the goods.
Old Sep 15, 2004 | 11:16 AM
toxic99's Avatar
Invest in a digital fish scale. They are cheap (like $20) at Wally world. Considering you got 8 runs out of the bottle on a 75 shot, I would say you got your full moneys worth. Get a bottle heater to get every ounce. You can get them as cheap as $60 along with a $30 adjustable pressure control switch.
Old Oct 22, 2005 | 11:19 PM
Sunny's Avatar
Default Weight
How much should a full 15lb bottle weigh?
Old Oct 22, 2005 | 11:28 PM
Robert56's Avatar
33 pounds, and sometimes the bottle will get so hot from filling that you'll be hard pressed to get your entire 33lbs. But there is a cure, just hold your bottle upside down and open valve and spill a little n2o and you will feel the bottle temp come right down, allowing you to get your last few pounds.
Robert
