Easy NOS kit to fit on LS6
Old Dec 16, 2004 | 09:40 AM
jellison's Avatar
Default Easy NOS kit to fit on LS6
Is there a simple kit that can be fitted to an LS6 engine?
Std but with a 17hp ecu upgrade - I prosume this would stay untouched?
Not in a Vette - TVR.
Cheers Jon
Old Dec 16, 2004 | 10:06 AM
Nitro Dave's Nitrous Outlet's Avatar
Jon,
This post is a little hard to follow.This is what I got from it.You are looking for a easy,uder freindly kit to install on your LS6 ingine.The car is stock other that a custom tune which gained you 17 hp.Its not in a vette but in a TVR.What is a TVR? Did I get most of this right?
If so The easy to install kit but great quality would be the Nitrous Express Stage 1 system.If you have custom tunning that advances timing you may need to pull some timing out.
Hope this helped.
Thanks
Dave
Old Dec 16, 2004 | 11:41 AM
DynotuneN2O's Avatar
LS1TECH Sponsor
The DynoTune LS6 nitrous kit is available in the UK through www.turbobits.co.uk
It is a turn key system made for the LS6.
Dan
Old Dec 20, 2004 | 03:21 AM
jellison's Avatar
Sorry I sounded confused - Engine will be standard bar a 17bhp extra ecu tune over a standard LS6 - would that be 422hp at the flywheel (how accuracte woul that be high or low if actually dyno'ed).
A TVR is one of these - very light about 1.1 tonnes - was a 302 Buick / Rover engine in 275hp spec.
I'll check the links posted.
Attached Thumbnails Easy NOS kit to fit on LS6-purple-monster-front-no-number.jpg   Easy NOS kit to fit on LS6-purple-monster-back-no-number.jpg
Old Dec 20, 2004 | 05:45 AM
jellison's Avatar
Dave - checked the site. I have seen a clip from a Scandalous Street Racing page that does a quick plum in of a bottle system to rental car - not sure I want to change the MAF. Like the system on here http://www.scandalousracing.com/videos/ the miami vette.
Old Dec 20, 2004 | 11:12 AM
The kit you are refering to is the incognito kit.It is good for up to 50hp.
Dave
Old Dec 20, 2004 | 12:29 PM
Noyzee's Avatar
8 second mod
If i get my Z06 in the spring, i will be getting a Dyno tune>>>>
it looks sweet, and is plug and play for an ls6.
Old Dec 21, 2004 | 05:44 AM
jellison's Avatar
How easy is it to plumb the Incognito system in? And presumably I could get order it with a larger bottle?
Old Dec 22, 2004 | 10:05 PM
StangStomper's Avatar
Dave
The Kit we used on our Scandalous vette was good for up to 300 horspower and we put it together.....If you run just a simple 150 dry shot, its plug and play, you dont need to change anything!
And you can put the bottle just about anywhere and activate it from just about anything.
Peter
Old Dec 23, 2004 | 07:42 AM
JoeyGC5's Avatar
Nice car! I thought the TVR's were powered for the 4.6 Mustang motor??
Dyno Tune gets my vote.
Oh, is there any difference between yours and I think it's a TVR speed 12??
Old Dec 23, 2004 | 11:14 PM
Phoenix 5.7's Avatar
TVR! I wish the US got some of those awesome european cars like the TVR, Spyker, Opel speedster, etc. Those kits above should be good, there are plenty of easy kits that don't require big mods.
Old Jan 21, 2005 | 08:27 AM
jellison's Avatar
Joey - they run Rovers (which is a bored and stroke olds engine from the mid 50's - to 5.0litre good torque, reasonable power.)
Not really related to the Speed 12 (very loosely in looks) they only ever made a few of these - they had hand welded blocks (steel) with Tuscan (straight 6 4v head 4.0 litre) and these 7.7 litre MONTSERS were good for around 800bhp without air restrictors (650 with) - they were way to fast (Mclaren F1 and then some pace) so they never got any onto the road for real clients only racers. Not just straight ine cars either.
http://www.ultimatecarpage.com/frame...php&carnum=799
The top cars they make now are a Supercharged 4.0 with 500bhp weighing approx 2400! Mental.............
Old Jan 21, 2005 | 12:07 PM
i have to say, TVR has the weirdest headlights ive ever seen on a car.
Old Jan 21, 2005 | 12:32 PM
TEA Brent's Avatar
i have an NOS direct port noszle kit with carbon bottle it is the easiest direct port kit available
Old Jan 21, 2005 | 04:41 PM
JoeyGC5's Avatar
Jellison, thanks for the clarification That thing should fly with any of those kits recommended.
Old Jan 21, 2005 | 04:54 PM
The car looks sweet.
Dave
Old Jan 21, 2005 | 09:55 PM
Robert56's Avatar
My vote (I like dry) is the versitile NOS 5177 dry that works great on the ls1/ls6. Check out my web site for some installed photos. Check links for some good n2o information.
Old Jan 21, 2005 | 10:17 PM
fredv's Avatar
last time I saw a TVR was 1975, WOW
it was a cool car then, it still looks good with a LS6 it should rock
go dry
