TECH TIP “KEEPING your nitrous supply clean.”
Always use a nitrous filter on your bottle while filling the nitrous bottle. Most refill places have filters on the inlet side of the pump. That stops trash from hurting the pump. But I am talking about a filter on the inlet side of your bottle; to catch anything that the pump might have missed or put out.
The use of a quality filter is a most. Simple have your refill station fill your bottle though your secondary filter. This other filter, will double the chances of catching any debris that might get into your bottle.
Take your filter and turn its position so that the flow is going into your bottle while filling. Once done turn the filter around so that the flow is coming out of your bottle. (I would recommend this immediately after refilling.) This way you will always keep the dirt on the inlet side of your filter. I know there are some filters that can be burped before turning then around. This is ok if you mfg recommends it. But there should only be a very small amount or trash if ANY that got to your filter. So as long as it’s a large quality filter, you should not have to clean or replace it for a long time.
Ricky
Ricky
I bought the NX filter and it is leaking from both the in and out sides. I tightened it down as much as I could before I thought I was going to break it. So how can I fix this? Should I use some thread sealer or something?
Ricky
Charlie
how about a half hour show on the speed channel that talks about nothing but N2O!! think of the possibilities: installs, tech tips, dyno and real world results, shoot outs and not to mention the marketing for NX!!
just a thought.
Ricky
I like using red loctite on all pipe thread fittings over teflon paste. It is easier and cleaner to deal with.
Ricky
Charlie
Ricky
Ricky
thanks
taner
