Single stage 250 shot or 100 NOS "Dry" & 150 TNT "Wet" 2 stage
Well... after deciding to do a 250 direct port shot on my Z, and discussing it with a few people, I'm beginning to wonder about traction issues. I'm an M6 (might switch to a TH400) and I'm not sure what a 250 shot will do to the tires when the window switch kicks it on. So, here's my question. Would I be best to stick with the single stage 250 shot, or keep the 100 dry that's on the car now and add a 150 TNT kit?? I figure I could add another window switch and have it come on at about 4000rpm. The TNT kit would deffinatly have it's own fuel system. Any thoughts on this.
I would vote for the 2 stage dry wet too. I'm really thinking of doing that for the spring too. Are you still on the stock bottom end? If so, don't forget that the TNT 150 is actually like a 175+ at the crank. You may want to stick with a 50-75 dry and then the TNT 150.
If you really want to do a direct port set up, a progressive controler would work perfect for you.
Well if the 408 is built specificly for nitrous why not go with a 2 stage direct port set up. You could give it 100-150 off the line then hit it with another 200. It would obviously cost alittle more money but it would be a nice set up for sure.
Even a large single stage progressive shot might work well for you.
Thanks. Best et is an 11.70@122. This was with the 100 dry shot and no suspension mods other than QA1's, panhard rod and strut tower brace. It's capable of better, just with a different driver and better suspension. Come on 408, BIG nitrous, suspension and some ruthless gear slamming. Gotta go faster this year. The cars around here are getting FAST.
My suggestion is to ditch the M6 and get the 400. Then while you're down there cut off all the wires to the window switches and install a momentary switch that you can hold in your hand.
The manual switch will allow you to control spin. If you break em loose instead of having to back out of the throttle you can just let off the button till they hook. If you get out of the throttle the run is done... period. Get some good tall tires and a moderate stall 2800-3400 (I prefer the Yank nitrous converters) and bottle it right off the line. Why would you ever want to not engage your bottle right away??? If it don't hold the tires then it's not that you are making too much power lol... you are lacking chassis setup to put it to the ground. Never curtail power to make up for a weakness in other areas. Fix the other areas.
