10lb bottle or 15?
Old Jan 24, 2005 | 09:39 AM
acsf's Avatar
Default 10lb bottle or 15?
I am getting a NX MAF kit and need to decide on bottle size. This is on a stock 02 Z28 with LT headers. What are the pros and cons of each. ie: How much longer does it take to heat a 15 vs.10? How much longer can I go with a 15? Can a 15 fit in the spare tire well with the NX remote opener?
Old Jan 24, 2005 | 10:15 AM
hellbents10's Avatar
LS1Tech Sponsor
A 15lb'er is nice if you can fit it. The bottle presure will stay more consistant during a run.
Old Jan 24, 2005 | 11:33 AM
GM Muscle's Avatar
Yep, I vote for the 15lbs bottle too. Nitrous goes pretty quick so the more you can carry with you the better. They generally come up to pressure pretty quick. But when you only have a pound or two left in it, it's almost impossible to get up the pressure up above 800-850psi.
Old Jan 24, 2005 | 11:34 PM
Robert56's Avatar
15lb'er here too. 1/2 as many refills.
Old Jan 24, 2005 | 11:49 PM
Poik's Avatar
I'd say 2/3.
One thing about the 10lb bottle is that it fits PERFECTLY in the spare tire area and allows for a battery to be located under it if wanted.
Old Jan 25, 2005 | 06:37 AM
30thz's Avatar
You can also put the 15 in the spare tire as well. I can mail you some picks if you like. If you remove your grill you can access the valve or you can use a remote opener. just pm me.
Old Jan 25, 2005 | 11:06 AM
acsf's Avatar
Thank you all for your input!! I'm going to go with the 15lb.
Old Jan 25, 2005 | 01:10 PM
30thz's Avatar
to those that pm'd me i'll get the pics out asap.
Old Jan 26, 2005 | 08:34 AM
TOZ's Avatar
TOZ
Had to go with my 15lb bottle close to me. Thats my remote opener.
Old Jan 26, 2005 | 03:56 PM
TNTramair's Avatar
hell....y not just get a 20lb-er and be done with it....
Old Jan 27, 2005 | 05:35 PM
30thz's Avatar
here's some pics:
