150 Shot
Old Jan 26, 2005 | 08:54 AM
TOZ's Avatar
TOZ
Default 150 Shot
How safe is really spraying a 150 wet shot. I have the window switch, and fuel safety device. My window swithc is set to shut down at 5800.
I really don`t want to start having problems with the car and want it to last me for a long time.
I run a 100 dry shot right now, but I`m doing the conversion to the wet kit so I can get more fuel mixed with the No2.
Should I stay a 125 ? I don`t really abuse the No2, I only run it once in a while, and never go to the track, even tho I`d like to go there once I have the 150 just to see what is doing.
Whats your advise ??
PS: I got bolt ons but nothing internal.
Old Jan 26, 2005 | 12:30 PM
GM Muscle's Avatar
Plenty of people spray a 150 shot with no issues. You already have some good safety items, so put a fuel pump in the car, get you A/F ratio and timing right, and you should have yourself a reliable set up. Just remember to check the fuel noid every now and then to make sure everything is working properly and pick up a good nitrous filter if you don;t already have one. Try starting with the 125, then once your comfortable with that make the step up to the 150 shot.
Old Jan 26, 2005 | 12:42 PM
white2001s10's Avatar
why not just jet up your dry shot?
Old Jan 26, 2005 | 02:40 PM
TOZ's Avatar
TOZ
Thanks man.
I really don`t want to jet up the dry system cause I`m running lean as of now, thats why I want to go to the wet kit so I can compensate for the fuel. And I really don`t want to tune it rich for the Dry either. Just want to make it richer on spray only.
Andrew you have a really nice set up man.
Old Jan 26, 2005 | 09:08 PM
Originally Posted by TOZ
Thanks man.
What you're saying can be easily done with a dry system.
What did you measure your AFR as on the spray?
How close is your nozzle to the MAF?
Old Jan 26, 2005 | 09:34 PM
Robert56's Avatar
Are you running lean because injectors are maxed? If so the cost to upgrade injectors compared to adding wet might be close. Or save A small 75 dry for the first stage (safety) and a full companion wet sys for second stage. That way you get the best of both worlds. Something to ponder?
Old Jan 27, 2005 | 10:47 AM
TOZ's Avatar
TOZ
I think it was 14 with spray and I`m at the Air lid.
Old Jan 27, 2005 | 12:57 PM
howierd42's Avatar
TOZ your sig pic is cool but your domain is expired.
ps: sorry for the hijack. I am interested in the oppinions on this n2o thread though.
Old Jan 27, 2005 | 03:35 PM
Remount your nozzle to spray directly at the MAF wires from about 2" away, then recheck your AFR to see where you're at.
IMO that's the best/easiest solution. If you have edit or a tricker box you can add fuel that way too.
Old Jan 27, 2005 | 04:22 PM
Wile_E's Avatar
I have a MAFT for $90 shipped if you (original poster in thread) decides to go this route and needs one.
Old Jan 27, 2005 | 04:27 PM
Homeslice (tm)'s Avatar
He won't need one if he jets up dry and does what White2001S10 suggests. That's the beauty of it. Worst case he'll need a CTS tricker box.
Old Jan 28, 2005 | 11:11 AM
TOZ's Avatar
TOZ
Thanks man I`m glad you let me know.
I still think I`ll be going wet anyways, I got most of the stuff for it.
Thanks anyways guys, just wanted to know how safe was it to got to 150 tho.
