Bottle Heaters
Old Mar 15, 2005 | 05:31 PM
TRYTHSS's Avatar
Default Bottle Heaters
I have a zex bottle heater and i dont like it, what are some good bottle heaters that you guys use? Do they have the automatic cutoff?
Old Mar 15, 2005 | 05:34 PM
TRYTHSS's Avatar
oh yeah..... has this happened to you, the other day i left my bottle heater on when i got home, after about 10 minutes my factory alarm started to go off, i couldnt figure out what was going on so when i went outside it did it again. Then i remembered that i had left the heater on, so after i turned that off my alarm didnt go off anymore..??
Old Mar 15, 2005 | 06:09 PM
Formula1999's Avatar
DynoTune Automatic Nitrous bottle warmer..
http://www.speedshop.org/store/scrip...p?idproduct=17
Old Mar 15, 2005 | 06:50 PM
7901 WS6's Avatar
Default new Question
What does anyone think in NX products that is
FOr the bottler heater vs the fire and ice,
I need a heater for my nx kit, and i just want to know what would be a better way to go genx or fire and ice.
thanks
Old Mar 15, 2005 | 07:56 PM
'02SS's Avatar
i got the 860 heated bottle brackets and i love 'em.works fast and looks clean;no GAY-*** orange piece of crap wrapping around my bottle.plus it comes with wing-nut style quick d/c for the main feed line;as well as the brackets.
Old Mar 15, 2005 | 08:02 PM
kapedogg's Avatar
Who makes those brackets? Sounds like the best set up around
Old Mar 15, 2005 | 08:03 PM
nspr8td lt1's Avatar
i have the nx warmer, it wont over pressurize the bottle.
Old Mar 15, 2005 | 08:55 PM
Nitro Dave's Nitrous Outlet's Avatar
860 performance.
We carry them.There was recently a price chang.We have noyt updated our website yet.They are now 199.00.Here is a link.
http://www.nitrousoutlet.com/outlet/...&section_id=61
Dave
Old Mar 15, 2005 | 09:16 PM
Well here is how I feel on the heaters.
There are three that I like.
I like the slick look of the Nitrous Express.The black element looks nicer than any element style heater I have seen.I also like how the transducer has ends on it to where you can unscrew the wires to disconect the wires instead of cliping them.
I also like the connectors that come in the kit.
I like the price of the dyno tune.I also like the fact that the transducer is adjustable.It also seems to have all the needed items for installation.
I like the 860 heater because it is more like a hot plate.It also comes with a hex to wing adapter to make easy axcess of removing your bottle.With this kit the heater and the brackets are one peice.You will need no tools to remove this bottle when it is time for a refill.I think that 860 has trully came out with something that is unique.When I first seen this heater it was the only kind on the market of its kind.
I have looked at all three of these systems.I have hooked up and used the 860 and NX heater.I have never had a dynotune heater.However reputation speeks for its self.Customers let you know if something is not up to par.All three of these heater get great reviews on the boards.All three companys are ran by stand up people that stand behind there product.Look at the pros and cons of each heater and pic the one you like best you cant go wrong.
Dave
Old Mar 15, 2005 | 09:27 PM
Shuck's Avatar
I have the dynotune bottle heater and it shuts off at a certain pressure. It is a good product.
Old Mar 16, 2005 | 11:15 AM
DynotuneN2O's Avatar
LS1TECH Sponsor
Dave summed it up nicely, all three are excellent products. Its just a prefrence, if you need brackets as well definalty go with the 860 unit. If you like the black heater element go NX. If you like adjustablity and money in your pocket, go DynoTune (www.DynoTuneNitrous.com). you can go wrong with any of them!
Dan
Old Mar 16, 2005 | 11:52 AM
koolrayz's Avatar
Dan,
I got the heater and control center today. Very nice
I cant believe how fast you shipped I placed this order over the weekend and I already have it
While I havent tried my new heater I can tell you I hated the controls of my NOS heater. I ended up bypassing them and whatching the pressure manualy. Your control center with my wideband commander will look
Old Mar 16, 2005 | 11:53 AM
Ole1830's Avatar
Just curious.
What specifically don't you like about your Zex bottle heater?
I've had mine installed for a year and a half with zero problems. Mine's on the rear window defrost circuit, btw. Very handy.
Matt
Old Mar 16, 2005 | 12:04 PM
Z284U2TRY's Avatar
dyno tune good stuff big heating surface.
Old Mar 16, 2005 | 08:17 PM
TRYTHSS's Avatar
the reason i dont like it is because mine just will not get the psi over 900-950. i want something that will get it into the optimal range @ 1050psi.
Old Mar 16, 2005 | 09:23 PM
Robert56's Avatar
remember if you increase your bottle pressure over the kits manufactures psi reccomendation it's like increasing your n2o jet and you could go lean.
Old Mar 17, 2005 | 01:41 PM
TRYTHSS's Avatar
well i thought on any kit that 1050 psi was the optimal range you want to be in. If that is not right then i wonder what mine is supposed to be at (NOS Kit #5177), i just bought the zex heater because it was a little bit cheaper.
Old Mar 17, 2005 | 09:10 PM
Robert56's Avatar
Not totally true as some manufacturers set up their kits at 900/950psi like NOS. However, with a dry kit, as long as you have the capacity with injectors the maf will read the extra n2o (read: pressure) and make adjustments accordingly. Wet kits, if you up pressure on bottle and do not adjust fuel jet you could go lean. So, if you up your press on the 5177 it will be added hp to the manufacturers rated hp, but should not be a problem if your not maxing out your injectors.
Old Mar 19, 2005 | 08:21 AM
kendo347's Avatar
I went with the nos warmer due to the fact that it is rated at 300 watts as compared to 240 for nx. The bottle will warm up quicker. However, the thermostats are set for 900 psi. All warmers should come with the temperature controlling thermostats. I dont remember the exact temp., but I think the nos warmer comes with an 82 degree thermostat. I left the t stats out once and it started to melt the rubber heating pad.
Old Mar 19, 2005 | 08:09 PM
Robert56's Avatar
Kendo347, you can change the 85 degree stats for 95 degree'rs. In the photo section in my web is pic and link about the 95'ers. Pic # 38 I think. This will up press to about 1000/1050psi or so.
