Valve stem
thanks,
Justin
If particles get in your solenoid or jets you may have big trouble. You may want to install a fuel filter to be safe.
The only thing I can think of is get a light and look in there as best you can and if you see anything try to fish it out with out pushing it farther in. Then I would clamp a hose over the end and put the other end in a bucket. Have a helper turn the key on and hopefully it will flush any loose pieces out. Be very careful about any kind of spark so you don't burn yourself up.
Good luck and like they said get the right tool next time.
