NX Maximizer II dyno tests inside with dyno graph
The motor is making about the same power it was on motor as last time except this time it was on 28 inch ET drags with 25 psi in them. It made a best of like 545 rwhp. I made the first run on juice with the setup starting at 0% at 3200 rpm and ramping with rpm to 50% by 6800 rpm. It made like 700 rwhp. Last pull was same start point but rapming to 100% (of the 200 shot jets) by 6800 rpm. On that setup it made 755 rwhp or so. Tq was very controlled...which is exactly what i wanted. It was a mild 669 rwtq or so. As a matter of fact the 755 rwhp was done with about 2 gallons of 100 octane and about 7 gallons of 93 in the main tank...and C16 on the front fuel system....FULL TIMING of about 27 degrees. No knock or detonation. That really because the mild TQ numbers along with the C16 accounting for roughly 25% of the HP being made. When I up the shot I will be retarding timing some and adding 110 to the main tank. AF will need to come down to 11.5 as well.
Overall I am very pleased with the initial runs. The next graphs I post on this combo should look significantly different, especially when FJO releases the multi point ramps. Tq will come on sooner and be more flat. And it will carry out to 7000 rpm without dropping off. Goal is 750 rwtq at 7000 rpm (999 rwhp).
Here is a graph from today. Note the very smooth transition from NA to juice.
The Max II is SEAMLESS in the RPM mode. I cant wait to hit it with the 450 shot.
BTW...I drove the STREET car 25 miles in rush hour to get to the dyno
Good job though, you know your stuff.
Robert
I am looking for some 10.3s @ 130+ or so NA and then hit it with the 450 shot...if its possible for me to drive it like that.
Im scheduled to run it this sunday.
I really like the fact that you can bring the nitrous in gradually based on rpm. Having the ability to do this allows users to spray even more nitrous safely and make big power like the turbo guys while having the advantage the instant hit of nitrous as well.
Thats a fact. It all makes sense. And there is another advantage to the MaxII I was thinking about last night. A buddy of mine that is building a Porsche 944 body with a 500 ci mopar engine with the NX SX2 dual system may end up using the MaxII. And we were discussing the merits of using the system in rpm mode or time based for manual VS auto cars at the track. At first glance it seems obvious that a time based setup is best for an auto. Obviously you bring in juice over time as traction is available and more HP can be applied. This basically will get you through first gear in time mode. But every gear after that will drop in RPM somewhat and then climb to the next shift point. So with the MaxII you could have one stage bring in power over time with traction until it reaches 100%. Then supplement your rpm levels with the second stage in rpm mode after first gear.
That would be kind of cool.
Good see all is working well..
Ricky
Robert
Robert...yes I have results from sunday....the SPEC stage 5 isnt going to hold..at all
I am probably ditching the T56
