View Poll Results: where should i put the bottle
on the driveshaft hump between the back seats
37.30%
in the spare tire well
62.70%
Voters: 764. You may not vote on this poll
where to mount bottle
Old Aug 22, 2006 | 12:44 PM
  #121
TT LS2's Avatar
Originally Posted by DropTopBird
I put mine between the back seats. I used a piece of 12x24 aluminum and bent it in two places to slide over the hump. After a few hours in the workshop shaping it to fit i just drilled 4 holes for the bottle bracket and secured it with the seatbelt bolts to the interior. Holds a full 10lb bottle no problem. Ill try to get some pics soon.
This sounds like a nice set up, Can't wait for the pics......
Old Aug 22, 2006 | 12:58 PM
  #122
TRMIN8R's Avatar
Originally Posted by 02 Camaro SS
TRMIN8R, how much are you spraying?
I'm on the 150 shot now. Used to spray 200 before I got the heads, intake and rear though.....
Old Aug 22, 2006 | 01:06 PM
  #123
trigger1's Avatar
Old Aug 24, 2006 | 02:57 PM
  #124
Bharnz's Avatar
I voted for the spare tire well.
If you get pulled over for speeding, you would probably more likely get a ticket, if the bottle is in his face.
Old Aug 28, 2006 | 05:51 PM
  #125
stevethepirate's Avatar
Old Aug 28, 2006 | 11:15 PM
  #126
slowpoke96z28's Avatar
where's the fuel tank?
Old Aug 28, 2006 | 11:24 PM
  #127
qwik_ss's Avatar
Originally Posted by Matt D
Yeah, oh well, i had to drop the tank anyway to throw the new pump in.
is it hard to drop the tank?
-Ivan
Old Aug 29, 2006 | 10:02 AM
  #128
in mine?
i relocated it to the hatch, where the t-top well used to be. better weight distribution.
Old Aug 29, 2006 | 01:16 PM
  #129
99FormulaM6's Avatar
why'd you jet it down?
Old Sep 11, 2006 | 10:53 AM
  #130
TRMIN8R's Avatar
Not enough fuel.....
Old Sep 12, 2006 | 11:58 AM
  #131
GuesDog's Avatar
Click here to watch bottles-0001
thats where I put mine, pretty sneaky huh?
Old Sep 13, 2006 | 09:37 PM
  #132
only problem is, there are so many raceheads here in houston, its only a matter of time before someone would steal a setup like that. if i was the only car enthusiast in the area, thats where i would put them.
Old Sep 17, 2006 | 06:22 PM
  #133
WickedRamAirWS6's Avatar
I have an F-Body and mounted my 10 lb. bottle in rear hatch area behind the rear seat using the two bolts already in place for the tie down points, you know the two triangle shaped clasps. I did this to prevent from having to drill holes in my car. i fabbed the bracket out of 1/4" X 1" flat stock and actually raised the bottle up off the trunk surface so it's at an angle kinda up in your face. it was easliy seen through the rear glass..till i painted the bottle and brackets black...now it's kinda in your face stealth style...
Old Sep 17, 2006 | 07:46 PM
  #134
pics?
Old Sep 17, 2006 | 10:47 PM
  #135
Gold Z's Avatar
I use a 15 pound bottle with a remote opener and a bottle warmer. The custom made bottle blanket is heavily insulated. My hatch glass has limo tint on it so you cant see through it to see the bottle setup. Paking the car in 100+ degree Texas weather has not caused any excessive bottle pressure problems. The bottle is very easy to get at to refill. I still have the deep well area to store my t-tops or anything else I need to carry.
Old Sep 26, 2006 | 10:02 AM
  #136
99blancoSS's Avatar
Where is the blow down? I cant see it in the picture? I see the feed line but I dont see where you've routed the blow off?
Old Sep 27, 2006 | 11:30 AM
  #137
Gold Z's Avatar
I don't run ablow down tube on the street. At the strip I use the heavy flexible tubing and route it out the drivers side fenderwell.
Old Sep 30, 2006 | 01:55 PM
  #138
Slowpoke310@APF's Avatar
just got pics of mine, suspended from the interior of trunk
Old Oct 2, 2006 | 08:17 PM
  #139
02NHRAtransAm's Avatar
^ wtf?!?!?!?
Old Oct 2, 2006 | 10:01 PM
  #140
.wow.
