how much no2 is to much?
Old Oct 13, 2005 | 11:27 PM
ZeroTraction's Avatar
Default how much no2 is to much?
whats a safe amount you would want to run on a ss 6spd stock??
Old Oct 13, 2005 | 11:31 PM
ITSTOCK's Avatar
150 shot on a bonestock car (meaning fuel system in this case). The limit is pretty endless on your bottom ends though as long as the fuel gets there.
Old Oct 14, 2005 | 09:07 AM
Nitro Dave's Nitrous Outlet's Avatar
Safely you can spray up to 150 with a fuel pump upgrade.
Dave
Old Oct 14, 2005 | 09:25 AM
00Vette's Avatar
Dave
How hard is it to upgrade the fuel pump on a C5?
Old Oct 14, 2005 | 11:39 AM
Airwolf's Avatar
I did mine alone with a floor jack in under 2 hours. I could do one now in less then an hour knowing what I know now.
Old Oct 14, 2005 | 12:19 PM
Noyzee's Avatar
8 second mod
how much no2 is to much? NO SUCH THING!!!!!!!!!!!
j/k. im with them 150 or so
Old Oct 15, 2005 | 05:57 PM
so i can run up to a 150 shot without doin anythin tot he car but installin my nx kit?
Old Oct 15, 2005 | 06:21 PM
Turo's Avatar
I wouldn't. For a 150 shot I would get an in-tank fuel pump (like Nitro Dave mentioned a few posts up), and for ANY shot you will need colder spark plugs (if you're still running stock heat range plugs), something like NGK TR6's. Both are fairly simple/cheap upgrades, but definitely worthwile if you want to play it safe.
