need some opinions from nitrous guru's
i am getting ready for some major mods of my 98 Z28. pretty much listed in my signiture. gonna do a 408, direct port, th350, 9 inch, supension, the whole deal.
here is my deal. my 408 consist of the following parts:
zero decked 6.0 block
-bored .030 (4.030 bore)
-Eagle H beams (ARP hardware)
-Eagle 4",4340 stroker crank
-JE gas ported nitrous pistons (-14cc for 10.5 to 1, with 65cc LS6 heads)
-ARP main studs
-ARP head studs
-Cometic gaskets
-ported/detailed LS6 oil pump
-Comp Cams timing chain
-Comp solid lifters
-cnc'd LS6 (243 castings) flow in the 328 @.650
-bronze guides, 2.05, 1.6 ss valves
-Bullet springs
-Bullet racing custom ground solid roller
i am changing the motor back over to a hydraulic cam. i dont want to deal with the solid roller stuff right now. i am gong with a 248/258 646 lift cut on a 112. my concern is the 10.5:1 compression ratio. i plan to hit this motor with a 250 shot and maybe move up to a dual stage setup down the road for a full 400hp hit. is the 10.5:1 compression ratio gonna hurt me? should i switch the pistons for some -2cc Diamonds for a 12:1 compression ratio? i still plan to drive this car on the street quite a bit. 110 unleaded race gas is available at the pump in town for a whopping $4.25 per gallon. 10.5:1 runs on 93 ocatne. i guess the big question is how much am i gonna give up HP wise with the lower compression? what are you guys opinions on which direction to go?
i appreciate any help and advise.
-ARP main studs
-ARP head studs
-Cometic gaskets
-Comp solid lifters
-Bullet springs
If your motor is already assembled I personally would leave it alone and use it as is. If you want a bit more compression you could take those 65cc heads down quite a bit for a lot less than buying and having someone put in new pistons. That may not get you 12 to 1 but it would be a nice bump. 10.5 will work just fine for nitrous. I think even at 10.5 to 1 you will be able to make more power than youll know what to do with running a sizable shot like a 300+.
right now the motor is assembled with the solid roller cam with .702 lift. i am pulling that cam to put in my hydraulic spec'ed above and changing the springs on the heads. i have no problem changing the pistons myself, i just dont see spending the extra $600+ on new pistons if i can get the times i am after with the current compression ratio.
if your goals are the times in your sig you will be able to make plenty of power to achieve that. You could do it with say 500 rwhp NA + a 150 shot if the chassis is setup well. Going back into the motor and spending cash on new pistons doesnt make sense to me. I mean we are talking about the difference of spraying a 240 shot with the 10.5 to 1 motor to make the equivelent power of the 200 shot on the 12 to 1 motor (rough estimate). Some $6 jets sounds better to me than some $900 pistons
the suspension is gonna consist of a full tubular front end (k-member and upper/lower a-arms), adjustable tourqe arm, adjustable rear contol arms, and anit roll bar. gonna go with Strange brakes front and rear also. should gain plenty of adjustablity and shed some weight.
took the heads to FFHP today. found out they are 59cc. that will bring my compression ratio up to 11.27:1 which suits me fine. intake runner was 238cc's and exhasut runner was 90cc's. didnt get a chance to flow them yet. i have also decided to stick with my current solid roller set up. i want to pull as much out of this combo as possible.
I personally would go with the larger duration one with smaller lift. I dont know what kind of springs you have on your heads or who did the setup for them....but when you start getting up over .700 lift its difficult to get a spring setup to work well unless there has been some serious mods to the heads. They will have to be in the 1.55 od and 1.900-1.950 installed height range.
Also most LS6 style heads will stall at higher lift over .620-.650. That doesnt mean youll lose power necesarliy but it may be benificial to keep duration longer and lift lower for best results.
they are setup for the needs of the cam in the motor. good springs, install height, and so on. i have no doubt the head setup will work. i just plan to drive the car some on the street and wondered if i could make similar power with the smaller lift cam due to the longer duration? at this point in time the shortblock is completely assembled with the higher lift cam. i am just over thinking the setup looking for more power. i guess thats how it goes when your this close.
givin the choice of the two cams...I think you will make substatialy MORE power with the larger duraation and lower lift. It will be a rougher idle for sure and probably have some bucking under staedy driving at certain rpms.
The 249 cam will drive a bit better.
You can alwasy try the cam thats in there and if your not happy swap it out later.
true. i put an offer to buy the other cam (260 266 on a 112 Valve Lift = .668). i figure i will try what is already in there due to it being assembled. if i dont like it will slip in the smaller lift cam and give it a shot. that way i have some options atleast.
