NX low cost digital progresive controller
Old Dec 8, 2005 | 10:43 AM
95ttoplt1's Avatar
Default NX low cost digital progresive controller
Any one here running one of these? How do you like it? What can you adjust? Is there a place where I can dowload the software and have a look see? ANy input is greatly appreciated.
Old Dec 8, 2005 | 11:13 AM
383LQ4SS's Avatar
that controller is the bomb. Go to FJOracing.com and find it on there. They will have a spot you can DL the software and run it through its paces.
I have installed a few no and they work much better than you would ever think. I am a big proponent of controlling the flow of nitrous VS rpm and this will alow for that. Limits the huge TQ spikes in the lower rpm.
Old Dec 8, 2005 | 11:15 AM
FormulaFire's Avatar
How hard are they to hook up.. I hated all the wiring on my N20 system already
Old Dec 8, 2005 | 11:25 AM
383LQ4SS's Avatar
considering the amount of control they offer they are very easy. Easier than wiring up a dual stage or something like that. The instructions are very good as well.
here is a pic of my dyno graph spraying a 200 shot with the controller in rpm mode. It starts at 3500 at 0% and ramps to 100% by 6000 rpm. Note the very smooth seperation from the NA line...especially on the TQ line.
AGain...this was starting at 0% and going to 100%. If you wanted to to you could start at 25% or 22% or whatever..and go to 100% and that would have the effect of kicking that Tq (and thus HP) up a little more in the lower rpms. Skys that limit as far as making your motor do what you want it too.
Old Dec 8, 2005 | 01:34 PM
Nitro Dave's Nitrous Outlet's Avatar
I have this unit on my 99 SS and I love it. The controller is a great add on for any nitrous system.
Dave
Old Dec 8, 2005 | 01:36 PM
Tony Shepherd's Avatar
I will be getting one soon!!
Old Dec 8, 2005 | 10:28 PM
95ttoplt1's Avatar
Hey thanks alot guy's that graph is really a good testment to how it works and Dave I will get in touch as soon as the wife gives me the OK (psssst christmas sale
Old Dec 9, 2005 | 10:38 AM
jerflash's Avatar
how well do these work on dry shots where the maf come in to play?
Old Dec 9, 2005 | 11:51 AM
383LQ4SS's Avatar
just as good. A very inexpensive setup for 700 rwhp is:
Walbro intank 255 lph pump
hotwire kit or voltage blaster
42 lb green top injectors
dry shot with one big noid to flow 300+
NX dual stage progressive controller
tuning
I have done this setup several times myself and many many locals have copied this and all have had perfect succes. Tough to get above 710 rwhp though. For that you either need direct port of use the above dry with a wet stage. All of that can be controlled by the dual stage progressive controller if you ever needed that much.
Old Dec 10, 2005 | 10:11 AM
XtremeLS1Z28's Avatar
What do you need to buy to use this? To me it looks like you need the FJO box and a driver. What does this all cost?
Old Dec 10, 2005 | 11:00 AM
383LQ4SS's Avatar
Im pretty sure for one stage it has a driver built in now. So all you need is the controller at $206. Which is unbelievable since it takes the place of a window switch and TPS already. Thos two items alone ar nearly $150.
Old Dec 10, 2005 | 03:41 PM
hondo's Avatar
th fjo site says has two 40 amp drivers so one stage wet kit or a two stage dry kit i think this controller is a hell of a deal.i was just playing with the software and its so nice and simple.
383lq4ss(al?)-- since you have some exp with this thing, does the 1st gear lockout work with an ls1?? just curious.
Old Dec 10, 2005 | 08:21 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
Yes First gear lock out work s on any car. This control is the best period onc eyou concider what it can do.
Ricky
Old Dec 10, 2005 | 09:06 PM
383LQ4SS's Avatar
works like a charm
Old Dec 11, 2005 | 06:27 AM
95ttoplt1's Avatar
anyone know the frequency for the solenoids? I am buying a kit that has a shark nozzle with Compucar solenoids, not sure what size yet. I am planning on a 200 shot with the FJO controller. this is on a lt1 also
Old Dec 12, 2005 | 09:48 AM
NXRICKY's Avatar
Ricky
Old Dec 12, 2005 | 08:25 PM
95ttoplt1's Avatar
Originally Posted by NXRICKY
14-16
Ricky
Thank you
Old Dec 13, 2005 | 11:33 AM
Y2K2LS1's Avatar
Actually, you can run both stages progressively if you wish.
Old Dec 13, 2005 | 06:56 PM
spanktu's Avatar
383,
is the curve from 35-6000(0-100%) linear or nonlinear that you programmed
I guess if you wanted it to hit like a turbo you could program in a "lazy" hit
that would probably work real well on the street.
Old Dec 13, 2005 | 07:31 PM
383LQ4SS's Avatar
The graph was just a test of 0-100% of a 200 shot from 3200 (0%) to 6600 (100%) and then off at 7400. So it was a linear line. I did begin to mess with the true curve options and they work great as well. Unfortunately i wont have time to do any more testing for a few weeks.
