Wetshot nozzle placement on LT1??
Damn how many times are we going to ask this question? You are like the third one this month. Use the search button.
https://ls1tech.com/forums/nitrous-oxide/477610-pics-need-asap.html
Darrell, thats a nice looking nozzle install. I did a single on a friends LT1 a couple yrs ago, I ended up placing the single nozzle on the outside bend, it was rubber/silicone which allows it to flex a little. On the inside curve it would pull it and make the pattern spray against the inner wall instead of down her throat. I like your layout there, good job.
Charlie
Charlie
Thank's Charlie. I tried to get the straightest shot possible to the TB.
Camaro94SS, I am unaware of a specific distance recommended from the TB. Mine is about 4 in. from the throttle blades. That is about as far back as you can go on that elbow and keep the nozzels aimed straight into the TB.
I placed them both on the outside of the bend. I had to tap both in on the bend which was a little difficult. I have both shooting right into the middle of the throttle body. Sorry, I don't have pics. KR went away and the #1 and #2 plugs now look fine.
The Vortec elbow has the divider which doesn't allow for both nozzels to be on one side. I think it would be a real pain to try to cut out the divider. Since you are using NX nozzels, I wonder if they have a straighter (tighter) spray pattern than the TNT nozzels. I will have to test the spray pattern with the elbow off the TB to see what it does. Thanks for the heads up.
