Nitrous Question?
Old Apr 23, 2006 | 04:54 PM
LS144's Avatar
Default Nitrous Question?
Okay guys I just bought a kit off here from one of the guys in the for sale forum. Its a zex dry kit, with one nozzle my question is what should I do to set it up good and RIGHT. I know a WOT and a window swtich I think im gonna get the digital one from MSD. And also a bottle heater and a purge basically just for looks. But I had someone suggest better nozzles wit ha T fitting to run a nozzle on each side of my lid. But personally I thought just buying an upgrade for a wet kit. Whatya guys think?
Old Apr 23, 2006 | 04:57 PM
camaroextra's Avatar
whast size shot are you gona be running? i suggest a fuel pump, if your doing 150 shot i suggest injectors too
Old Apr 23, 2006 | 05:06 PM
LS144's Avatar
Prob start out with a 75 shot then go to 100 nothing more than that. Is it oaky to do a dry on a 100 shot? I dont wanna blow anything up since this is my DD.
Old Apr 23, 2006 | 05:13 PM
Z2K_MrJ's Avatar
Board Certified Idiot
I thought the Zex Kits Came with a WOT built in allrdy . ???
Old Apr 23, 2006 | 05:16 PM
98's have 28lb injectors, 100 dry should be fine. just make sure everything is in working order
Old Apr 23, 2006 | 07:02 PM
BottleOrBoost's Avatar
Be careful using twin dry nozzles... Don't forget to half your jet size in each fogger. Probably an overkill though... If your fogger is mounted correctly, and pointed in the right direction, one fogger will work fine...
Old Apr 23, 2006 | 10:24 PM
LS144's Avatar
Basically the only thing Zex I want to be using is the bottle and lines. Id like to get some new noids also along with nozzles....Any reccomendations?? Also would it be worth it to upgrade to a wet system?
Where should I mount my nozzle and which direction?
Old Apr 24, 2006 | 04:15 PM
LS144's Avatar
Where is the best place on my lid to put the single nozzle??? and also based off of YOUR own PERSONAL use which nozzle you think is best for a dry kit?
