N2O guys with heaters please come inside!!!
I was thinking of mounting it to the small fitting in the side of the bottle, but when I have to remove it to fill it, having to take the wires off will be a pain in the ***.
The instructions say to hook the pressure fitting in the tee in line with the main nitrous line..........but I wanted to see what everyone else did.
Maybe there is a better way to do it.
Can you guys post up pics and explain why you plummed the pressure switch the way you did?
I put my pressure switch on the bottle and it stays there, all you have to do is pull the two spade terminals off when you pull the bottle.
I prefer it on the bottle (pressure side) because if you forget to open the valve and the pressure switch is on the other side of the closed valve, it will run the heater and never see a pressure increase. You run the risk of over heating the bottle and then venting the precious gas without using it through the blow down.
I have a Remote Pressure gauge and that is on the mainline on a Dynotune -4 swivel gauge port.
Email me for Pics if ya want them. I have two bottles (one a NX 45 Valve, the other a DynoTune Straight Valve, each have their own Pressure switch.
Beer
Beer
From what I think your trying to say, the bottle heater's bottle pressure regulator is screwed into the neck of the bottle and you just remove the two wires from the regulator by pulling them off. Okay that's simple enough.
But I don't understand exactly why you do it and I'm not EXACTLY sure where you have attached the regulator!
I'll send you a PM so you can e-mail me some pictures.
Thanks Beer! And I'm eagerly awaiting that panel.
You would never have to worry about leaving the heater on, because if the bottle is turned off there is no pressure for the regulator to read and turn itself on!
Here is a NX bottle. Vinny set this up so I can swap bottles (this is my track bottle, no opener).
It has two ports, so no manifold was needed.
I have a pressure switch on each bottle, and all it takes to swap is pulling the two spade terminals off the switch (the blue and red connectors in the photo first photo).
With the switch as photo'd it reads the bottle pressure and providing it is set correctly, no worries.
Now look at the first photo, and the Dynotune Pressure gauge on the mainline.
If you put the pressure switch there, and the bottle valve is closed and you mistakenly leave the heater on, it will not see the pressure increase in the bottle and keep cooking the bottle to potentially dangerous levels.
I'll have updated pics with the NX bottle in...I emptied the DynoTune Bottle
The valve cuts the heater off when the pressure reaches your desired psi. Therefore if you cut the heater switch on and the bottle is off then the valve reads 0 psi and the heater will stay on.
Option A
If you have several bottles and are not worried about forgeting to open them for the switch to read the pressure, then install the switch in-line. This way you only need 1 pressure switch.
Option B
If you only have one bottle then definetly install it into the bottle directly. It makes the heater completly fail-safe. It will never overheat the bottle, and if you forget to plug the switch in then nothing happens. Its a great approach, I personally forget everything as soon as I get to the track, so anything I can do to reduce the chance of error is in my best interest.
Plus you can heat the bottle with the valve closed which is nice.
Granted you will need to un-plug the 2 wires when you get your bottle filled, but its really no big deal.
Vinny
Option A
Option B
Vinny
However, my 860 bottle heater/bracket kit came with 2 blue wire ends for the regulator unlike the 1 blue and 1 pink like in the picture above!!!
Do I need to differentiate the two regulator sides, or is the switch the same as the noids?
Robert
Robert
But I have been meaning to ask you if you were going to make it to PR this weekend or on Friday. Are you heading out for the CCC, or do you have to wait for a while to get your clutch and install it? Let me know cause I want to be there when you run.
I also need to come visit for some more advice! I'm not sure exactly how to wire the switch panel that beer made for me.
You should see it.......it looks really sweet.
I figured how to wire the bottle heater and I think the arm switch should be no problem, but I'm not too sure about the purge wiring or the purge exit line for the purged nitrous. I'll come talk to you this weekend.
Robert
Robert
And if my fridge is empty there is a store literally within a 2 minute walk from my front door
Yeah, I basically just need help with the purge wiring and purge exit pumbing. There wasn't much in the way of exit pumbing for the purge noid.
I'm thinking I need to buy some tubing to route the exit for the purge.I'll have you take a look and show me what I need to do!
I'll call you on saturday. I should be getting the powersteering pump and pulley tomorrow. I plan on taking it to the dealership to have them properly install the pulley. Then I can install it myself! I don't have the equipment and last time I tried to mess with the pulley the back of the pump busted out from the bolt.
DynoTune Swivel gauge adapter (Blue on end of mainline).
860 Performance -4 Wingman (had to trim the wingnut to clear the swivel and pressure gauge).
NX Bottle
