Sprayed ......
Old Aug 6, 2006 | 08:32 PM
Alai-SS's Avatar
Default Sprayed ......
at the track the other night, first time on slicks. I'm only running a 100 shot but for some reason my Low traction light kept coming on. I know I had traction ( all though it doesn't exactly feel like it on slicks) anyone know what that might be?
Also, kinda curious to know how high I can up the shot and still be fairly safe.
Old Aug 6, 2006 | 09:09 PM
SPRAYIN96TA's Avatar
I would go no higher than a 150hp on a stock fuel system......I would get some good injectors and a good fuel pump....the spray the 150hp
Old Aug 6, 2006 | 09:37 PM
CAT3's Avatar
Restricted User
the low trac light came on after mid-track, like at the end when your letting off the throttle? If so, totally normal function of the system.
Old Aug 6, 2006 | 09:55 PM
Alai-SS's Avatar
yeah it came on around mid track. That is a big relief.
Old Aug 6, 2006 | 09:56 PM
Alai-SS's Avatar
I was somewhat worried about my transmission but I am buying a new one. I didn't even think about the fuel system. Thanks. What would u suggest for injectors?
Old Aug 6, 2006 | 10:32 PM
Ls1Won's Avatar
You shouldn't run with traction controll on the nitrous you'll bog and BOOM
Old Aug 7, 2006 | 08:43 AM
Alai-SS's Avatar
the traction control was off.
Old Aug 7, 2006 | 08:46 AM
CHEVYMAN434's Avatar
Default Low Trac Light
It's probablly because you have a taller tire on the rear.My car does that to.
Old Aug 7, 2006 | 06:24 PM
Alai-SS's Avatar
Actually, it wasn't much taller. I think maybe an inch. Hope, your right though. Thanks.
